Which fuel pumps U guys running 700hp+
Old May 4, 2015 | 10:23 AM
blue0453's Avatar
Dual 450s
Old May 4, 2015 | 06:38 PM
Livin Life's Avatar
X3 on the dual 450s. My truck made 700 rwhp on one 450 and 80lb injectors ( pump 93)
Old May 4, 2015 | 11:22 PM
chevrolade's Avatar
80mm turbo 12-14lbs 700rwhp ID1000 injectors 93octane
Dual 450s,if anyone sell a wire kit or the pumps ready to drop in? (2008 truck) or maybe even a how to...
Old May 6, 2015 | 05:05 PM
brandon6.0's Avatar
When i installed my dual pumps. I ran 2 fused hot 10gauge wires from battery to 2 relays. I used the oem fuel pump wire as a activation for one relay and a hobbs for the other. It alows plenty of current and makes things simple.
I also run a dbrods fuel cell so i had to extend oem harness anyways.
Old May 16, 2015 | 05:45 PM
I run one a1000 on the frame
Old May 16, 2015 | 06:27 PM
George C....'s Avatar
Formerly ScreamingL
Zach I just made 806rwhp on a mustang Dyno with that lingenfelter dual pump kit
If your capable I see no reason why can't work on trucks
Old Jun 19, 2015 | 05:30 PM
TrendSetter's Avatar
is there a way to support that much power with the stock tank that can run near empty like the stock bucket? at this point i think the most reasonable way is a surge tank...
Old Jun 19, 2015 | 07:34 PM
GMCtrk's Avatar
You can drive it down to low fuel no problem. But you'll get fuel starvation under 1/2 tank most likely. Stock48 was having starvation issues at 3/4 tank reportedly, although he was running in the 9s
Old Jun 19, 2015 | 09:54 PM
Atomic's Avatar
I have a gauge for that
I did that once...damaged a piston in the process. Not worth it. At the track I usually kept it about half full and never had problems but I made sure to keep the bucket intact.
5.3Okasai
Mar 9, 2022 01:07 PM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
dantheman1540
Jul 24, 2015 01:50 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
