fount mount
Old Jan 21, 2010 | 03:11 PM
onebad-chevy's Avatar
Default fount mount
anybody on put a fount mount turbo on a 2500hd 6.0l ?
Old Jan 21, 2010 | 04:00 PM
TrickTurbo's Avatar
Truck Sponsor
All the time. Lots have done it...
Old Jan 21, 2010 | 04:09 PM
do you have a kit for it with a intercooler and how much
Old Jan 21, 2010 | 04:22 PM
TrickTurbo's Avatar
Truck Sponsor
Yes we do. We have been building kit for these trucks for years and have had several requests for different things. So we are in the process of releasing a NEW kit to the GM market...
Old Jan 22, 2010 | 06:20 PM
JoeyGC5's Avatar
go here for my 2500hd on 35's with a KBRacing front mount. I'm running 8-10lbs right now.
http://s486.photobucket.com/albums/r...Turbo%20Truck/
Old Jan 22, 2010 | 06:50 PM
why did you have to relocate the batter also what are you useing for the fule system. didn't the hot pipes work that you get in a kit why did you have to mod the pipe from the driverside to passanger thanks
Old Jan 22, 2010 | 08:53 PM
JoeyGC5's Avatar
I mounted the intercooler and 3" piping, in the same area as a stock Duramax. As there would be to much to cutout to mount it in the typical 1/2 ton location. This required moving the pcm and battery for room to work with.
Nelson Perf supplied me with an intank 255 and I have Motron 60lb injectors with my stock returnless system.
I had to mod the crossover because of the 6" of lift on my truck, to clear the front driveshaft.. I didn't have time to make a new driver side/crossover so I used what I had available.
Old Jan 23, 2010 | 09:47 AM
thanks for the info i just have a levleing kit with 33 inch tires. did kbracing give you every to do the kit and where did you get the bracets for the battery and intrcooler
Old Jan 23, 2010 | 12:25 PM
lsxmalibu's Avatar
how/where did you put the turbo drain....
Old Jan 23, 2010 | 01:57 PM
JoeyGC5's Avatar
For the oil drain I dropped the pan and have a -10 fitting 1.5" below the pan rail top edge, above the low level sensor.
The kit I got from KB was his standard kit, only no piping was cut as typical for his shipped 1/2 ton units. I used a Duramax battery tray and everythig else is good 'ole time and welding slag. On all the brackets and mounts I used as much of the factory mounting points as possible to simplify things alot. Also I cut quite a bit out (then reinforced) of the lower passenger front inner fender to core support bracket to clear the overflow tank lines, ac lines, and intercooler pipe on that side.
nabozny21
Oct 17, 2015 07:47 PM
thewrx
Oct 6, 2015 10:59 AM
KINGCYCLES
Oct 2, 2015 10:21 AM
old motorhead
Sep 29, 2015 08:22 PM
DrX
Sep 29, 2015 04:31 AM
