force induction 4l80e guys
Old Nov 18, 2013 | 09:25 AM
tim wellington's Avatar
Default force induction 4l80e guys
have any of you guys .had ur 4l80e 1st and 2nd ratio in tranny change to 2.97 and 1.57
Old Nov 18, 2013 | 09:31 AM
03sierraslt's Avatar
Nope, I much prefer the 80e stock gearing. I hated the low first gear of my old 65e. Even with the 80e first gear I hit 1.65 60ft.
Old Nov 18, 2013 | 09:43 AM
00buckshot's Avatar
I'm the same, the gear ratio of them stock is perfect in my opinion, if you need lower gears, you need more power lol
Old Nov 18, 2013 | 10:04 AM
Vortec350ss's Avatar
I havent had the opportunity to really play with mine yet... but from a daily driving prospective I can say I think the gear ratio's are pretty good.
Fingers crossed I'll be able to report back a few WOT pulls with my FLT after this weekend...
Old Nov 18, 2013 | 10:06 AM
Default 4l80e gear swap
the reason i asked is because there is great tuner of fords.you know lot ford run chevy trans .he says there ford turbo cars and lighting truck slow down when swapping to 80e vs there (ford) 6 speed tranny with the lower 1st ans 2nd gear.so they do gear swap.says he like low gear in tranny and tall gears in the rear like 3.23 /3.15 /3.08
Old Nov 18, 2013 | 10:10 AM
I can see that with a roots or centrifugal blower assuming you could get it to the ground with such short gears... but a turbo kinda likes the longer gear to really help it load up and hit boost quicker.
As some one else said... if the gear is too long you aren't making enough power
Old Nov 18, 2013 | 10:33 AM
Gadgetized's Avatar
I really like the gear ratio. My truck will pretty much spin the tires at any speed in 2nd so power isnt an issue with my setup. I say leave it, and turn up the boost if it feels doggy.
Old Nov 18, 2013 | 03:16 PM
Default 4l80
thanks .think i just going turn it to 10- 12 lbs . i was on 7.5 lbs til i changed my rear end from 3.73 to 4.11 now only make 6lbs buts runs quicker.
Old Nov 18, 2013 | 09:55 PM
dmaxvaz's Avatar
should have went with 3.42s. spools faster
Old Nov 18, 2013 | 10:52 PM
TrickTurbo's Avatar
Truck Sponsor
Using the power more efficiently.
Lower gears allow the engine engine to rev cleaner and lug it down.
Time slip shows your on the right track.
Did not know you could swap gears out in the 80e. ???
