Flip the Radix J-tube?
Old Nov 11, 2011 | 12:36 PM
Smitty's '04 GTO's Avatar
Default Flip the Radix J-tube?
Quick question. Can the MP112H Radix J-tube be flipped to the other side to run the throttle body / intake off the drivers side of engine? This would be for a non-truck application...
Old Nov 11, 2011 | 01:13 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
No, the bolt pattern won't allow it.
Old Nov 11, 2011 | 05:45 PM
Rick_Vor's Avatar
Is there enough meat on the blower case to re-tap?
Otherwise, someone could either weld on enough material to re-drill the holes or make an adapter bracket. Something along the lines of this style...
Rick
Old Nov 11, 2011 | 06:28 PM
The shape is also wrong. It's sort of a wide D shape, so I just don't see that working at all. If you are a good aluminum fabricator, I suppose you could cut the mounting flange off the j-tube, and build your own new j-tube whatever shape & design you wish.
Old Nov 11, 2011 | 06:43 PM
TTownTech's Avatar
just heat it up and bend it the other direction
Old Nov 13, 2011 | 08:24 AM
Thanks for the reply w/pic, AKlowriderZ71. That's a quick, concise answer to my idea/question. I guess I'll stop thinking along those lines...
Old Nov 13, 2011 | 09:46 AM
TTownTech's Avatar
Fabbed tube would be pretty sweet if youve got the capabilities...
Old Nov 13, 2011 | 10:40 AM
Bill Reid's Avatar
Do you already have the Supercharger? Kenne Bell had an application where their "j-tube" came out on the driver side. I haven't seen a MP112/122 setup with a driver side induction. I would think one could easily mechine an adaptor (or fab one up) as mentioned earlier but I guess it depends on how much room you'll have to work with...
livefast1
Sep 25, 2015 07:31 PM
bagged7104SS
Sep 24, 2015 08:42 PM
YenkoST
Aug 28, 2015 01:42 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
