Flex Fuel pump Escalade out of pump?
Old Dec 11, 2013 | 06:06 PM
blownescalade62's Avatar
Default Flex Fuel pump Escalade out of pump?
2011 Escalade 76mm BB Turbo running Meth. I know they say these pumps will Hold to around 600-650RWHP. I think I running out of pump after extended WOT runs I start with 60psi idle but start dropping to 35-34psi A/F is still good on wideband? Running 8-10 psi 50# injectors.
What would be best upgrade pump? Also heard you could run a boost a pump off Flex pump with a bit of trouble? Not sure if its worth it?
Old Dec 12, 2013 | 01:50 AM
gamble686's Avatar
I believe the AEM 320lph pump is supposed to work well. The flex fuel pump is rated at about 200lph just to give you an idea.
Old Dec 12, 2013 | 06:27 AM
Atomic's Avatar
I have a gauge for that
walbro 400 or 450
Old Dec 12, 2013 | 07:29 PM
Can those pumps work with returnless fuel system complete drop in?
Old Dec 13, 2013 | 12:47 PM
damianldaigle's Avatar
Flex Fuel is 290lph not 200lph. Yes people are running the walboro 400-450. It's not a direct fit but they will work.
Old Jan 2, 2014 | 10:06 PM
TX Tahoe Z71's Avatar
I'm on my third stock flex fuel pump (third was a warranty replacement for the second) with a Kenne Bell boost a pump. If/when this one dies, I'm going Walbro 450, selling the BAP and never looking back.
Old Jan 2, 2014 | 10:37 PM
thanks I think I'm leaning the same way.
Old Jan 2, 2014 | 11:32 PM
Atomic's Avatar
Take that boost a pump bullshit off and it will last a lot longer.
GXPJAY
Feb 13, 2022 08:15 AM
05GMC4.8
Aug 7, 2015 09:55 PM
RS/SS 4.8
Aug 2, 2015 11:03 PM
Closer_2001
Jul 21, 2015 03:25 PM
lxcoupe
Jul 21, 2015 02:12 AM
