Flash stall with stock converter
Old Aug 5, 2009 | 07:33 AM
sharpshooter's Avatar
Default Flash stall with stock converter
What do guys think the stock stall would flash to in my set-up?The truck makes roughly 650 hp at the crank and weighs 5400 lbs.
Old Aug 5, 2009 | 09:26 AM
JoeyGC5's Avatar
1700-2000 just guessing. What does it flash to now, or have you got the setup running?
Old Aug 5, 2009 | 10:01 AM
00ChevyScott's Avatar
Wearin' da big hat
that procharger probably needs around a 2800-3000 stall for the best results.
Old Aug 5, 2009 | 01:55 PM
I'm looking for a more streetable set-up.It has a TT3000 in it now and it flash's well above 3000 and seems pretty loose on the street.My power level, weight and tire size are the reason for this.
I was wanting to see if anyone has run a stock stall behind FI and what it stalled to.
Old Aug 5, 2009 | 03:52 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
1800-1900 when mine was with stock converter.
Old Aug 5, 2009 | 03:57 PM
Wearin' da big hat
You can't really compare a procharger to a magnacharger. They make power at different RPMs
Old Aug 5, 2009 | 04:02 PM
Even if we have the same cam?
Old Aug 5, 2009 | 04:03 PM
Wearin' da big hat
yep..
Old Aug 5, 2009 | 04:06 PM
Ya, I was kidding about the cam thing.....but I think he could expect somewhere between 1600-1800 as an educated guess.
LCHEE
Oct 24, 2020 04:10 PM
bighouse
Sep 27, 2015 12:37 AM
KyleW707
Jul 29, 2015 08:17 AM
lo&sloSierra
Jul 24, 2015 07:03 PM
ZONES89RS
Jul 22, 2015 12:35 PM
