fixing my fuel pressure issues FOR GOOD!
Old Aug 8, 2006 | 08:56 PM
  #61
moregrip's Avatar
what a rush!
Originally Posted by Holty
i had to modify the bucket since the factory fill system no longer functions as designed. With the stock pump it had a pickup directly underneath the bucket which was connected to the pump to fill the bucket so the pump could just draw from the bottom of the always filled bucket to feed the motor. This was designed to keep the pump always in the fuel to keep it cool and keep fuel completely around the pickup so no air could be sucked in around hard corners or acceleration. since the new walbro pump does not have that extra pickup, i need to cut the bucket open to allow fuel in to keep the pump cool.
the 03 and down baskets must be different? wish I remembered what mine looked like
Old Aug 8, 2006 | 08:59 PM
  #62
Holty's Avatar
Notorious BIG
i'm not sure what the 04+ fuel pump assemblys look like, but i know that they are a returnless system and have the FPR in the tank (i think).
Old Aug 8, 2006 | 09:00 PM
  #63
Holty's Avatar
Notorious BIG
NOTE:
i forgot to mention that i also just replaced my FPR and my fuel filter. Will be changing out the inline fuel pump next week.
Old Aug 8, 2006 | 09:56 PM
  #64
dc_justin's Avatar
Hello Dave
yes, after much research, i belive that he was wrong also. however, several people have done this mod with no problems, i do not plan to be one of them.
no, i have no replaced my FPR. i will do so this weekend.
do you have anything else to add to this topic? am i going down the right path with the manifold barbs? compared to mine, how does you fuel pressure look? i'm getting frustrated because everyone said oh just get a magnavolt and that will solve your problems. it did not.
I'm one of the ones that installed an intake walbro 255. No problems to speak of. Wasn't difficult to wire it up either.
BINGO! thats my guess too. seeing that we have the EXACT same fuel systems, why would your pressure be so much better than mine?
My system read slightly low as well. Cranked the fuel pressure on the regulator a few turns clockwise and it was back in line.
Old Aug 9, 2006 | 10:47 AM
  #65
Holty's Avatar
Notorious BIG
do you have problems when your tank starts running low? please give me details on how much gas you can run in the tank.
Old Aug 9, 2006 | 11:15 AM
  #66
dc_justin's Avatar
Hello Dave
There has been one instance where I hammered it with less than a quarter tank and it sucked air at the top of first gear . Other than that one instance, I never have any problems at all.
The way I have mine set up right now (bucket drilled with a few 3/4" holes, pump filter within bucket) I'm sure that I'm missing out on a gallon or two. I'm going to eventually get around to setting the bucket up like BenKey has done. He cut the bottom of it out completely and mounted the pumps with the filters hanging out of the bottom.
Justin
Old Aug 9, 2006 | 11:21 AM
  #67
dewmanshu's Avatar
Moderately Differentiated
I like th e3/4 hole idea, if I was to have done it in the past when I was replacing my stocker, that's how I would have done it. Although BenKey's is probably the best situation.
Doesn't really matter however you go about it, nail it with hardly any gas in there and there is physically no fuel there to suck up, I don't care if your pump pick up is against the tank. Just be careful now that you are "dangling".
You know, now that I think about, I have a question, these holes and Holty your square, are they in the front part of the bucket? You know so at least when you nail it the fuel is hitting the holes/cut outs as it rushes to the back?
Old Aug 11, 2006 | 09:18 AM
  #68
Holty's Avatar
Notorious BIG
UPDATE: truck is a little hard to start now, it cranks for a little longer than it did before. i'm saying this is normal since i have 0 fuel pressure key on engine off.
Yesterday my CEL came on. its throwing a P0452 fuel tank pressure circuit low voltage. Anyone know why this would happen? i cleared the code and it didn't come back right away, but i havn't had a chance to drive the truck.
Old Aug 11, 2006 | 10:39 AM
  #69
DrX's Avatar
DrX
Is the connector to the sensor on the top of the tank module pushed all the way in or the wires damaged?
Old Aug 11, 2006 | 04:13 PM
  #70
Allgonoshow's Avatar
https://www.performancetrucks.net/fo...d.php?t=371859
see what blownchevy said in this thread, probably applies
