fixing my fuel pressure issues FOR GOOD!
Old Aug 7, 2006 | 10:05 PM
  #51
dewmanshu's Avatar
Moderately Differentiated
Originally Posted by BigBlackAv
do your have the return type and what kind of fuel pressure regulator are you getting? And fuel pump?
yes he does (return).
stock (fpr).
on the fuel pump in the tank, your guess is as good as mine what the crazy ****** is doing. He has an OEM intank now, he may just replace with and OEM but he may also put the time into dropping a walbro 255lph in there. He also has an inline pump...it will now be a walbro 255lph also...if he ever sent the wrong one back. He has enough goodies to HAVE NO fuel issues for sure!!!
There you go, a page from the Holty diary.
Old Aug 8, 2006 | 06:59 AM
  #52
Holty's Avatar
Notorious BIG
hehehehe, 255 walbro in-tank is going in as soon as i finish typing this. i'll post back later today with results.
Old Aug 8, 2006 | 04:05 PM
  #53
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by Holty
UPDATE: i re-installed my magnavolt, Correctly this time lol. Thanks Tony! anyway, it did not change anything. my fuel pressures are exactly the same as i posted back on page 1, although, i did not expect to see any fuel pressure changes. i've done several more WOT runs, none of which have i experienced my fuel pressure drop. either way, tomorrow morning, the new in-tank fuel pump, fuel filter, and FPR are going in. we'll see then.
The fuel pressure in a return style system will vary depending on engine load. The FPR not only sees boost but, it also sees vacuum and adjust fuel pressure accordingly. At idle there is a lot of vacuum on the manifold which will lower the fuel pressure. At WOT there is no vacuum(NA) or boost(blown of course) which will raise the fuel pressure. This is normal operation for a manifold referenced fuel pressure regulator like the '03 and back systems use. The numbers you posted earlier are not out of line from normal for a '03 system. The dip in pressure at WOT was not right though.
The '04+ "returnless" fuel systems should hold a relatively constant fuel pressure under all loads(assuming the fuel volume is available)
Old Aug 8, 2006 | 07:20 PM
  #54
Holty's Avatar
Notorious BIG
alright, the 255lph walbro in-tank pump is in. so far, so good. only one weird thing happening....key on, engine off, my fuel pressure jumps to about 56psi, then drops back down to 0psi. it never did this before,....key on engine off always bleeded off just a few psi, but never went down to 0....is this normal? otherwise, everything is good so far. WOT = 62psi, other than a higher WOT psi, everything else is exactly the same. right now i have 3/4 tank of gas, we'll see what happens as fuel level goes down. here are some pics.
NEW OEM GM fuel pump assembly:
modified stock fuel pump assembly:
Old Aug 8, 2006 | 07:48 PM
  #55
XLR8NSS's Avatar
Adkoonerstrator
Good deal. It sounds like the 255 doesn't have a one way check valve in it so basically once it stops "priming" the fuel just drains back through it into the tank. The only thing that might cause is a little bit of extra cranking on startup but, shouldn't be to big a deal.
I would've said it was a regulator problem but, your fuel pressure sounds good so that isn't it, must be the check valve deal.
Old Aug 8, 2006 | 08:36 PM
  #56
Holty's Avatar
Notorious BIG
thanks dude, i figured it was something simple like that.
Old Aug 8, 2006 | 08:40 PM
  #57
moregrip's Avatar
what a rush!
what are you expecting from the square hole in your fuel pump bucket?
Old Aug 8, 2006 | 08:44 PM
  #58
Holty's Avatar
Notorious BIG
sorry, i'm not sure i understand your question?
Old Aug 8, 2006 | 08:45 PM
  #59
moregrip's Avatar
what a rush!
looks like you cut a hole on the side of your basket, why did you do that?
Old Aug 8, 2006 | 08:49 PM
  #60
Holty's Avatar
Notorious BIG
i had to modify the bucket since the factory fill system no longer functions as designed. With the stock pump it had a pickup directly underneath the bucket which was connected to the pump to fill the bucket so the pump could just draw from the bottom of the always filled bucket to feed the motor. This was designed to keep the pump always in the fuel to keep it cool and keep fuel completely around the pickup so no air could be sucked in around hard corners or acceleration. since the new walbro pump does not have that extra pickup, i need to cut the bucket open to allow fuel in to keep the pump cool.
