Finally nice weather-RADIX 90MM/60# Injector mod in the back yard
Old Apr 25, 2007 | 08:16 AM
  #61
Wilde Racing's Avatar
How do I change this text
Originally Posted by dewmanshu
I had pcm problems before I started all of this.
Don't tell me you've thrown more parts on before fixxing a problem....
The throttle body look HUGE..
Old Apr 25, 2007 | 08:44 AM
  #62
dewmanshu's Avatar
Moderately Differentiated
Hopefully that Wilde Racing replacement PCM fixes the problem.
It's like maggie had intentions of putting on a larger TB. The flange around the opening cuts out and the "tunnel" of the tube is perfect. 90MM.
Oh, before I forget to mention it...Grippy once was made fun of for noticing an "edge" in the inside turn of the j-tube. IT'S HUGE. It definitely needs to be grind down IMO. But not by me, I am too lazy.
Old Apr 25, 2007 | 07:30 PM
  #63
dewmanshu's Avatar
besides I still need the replacement intake bolt...to replace the bent one...ONE MORE BOLT to tighten to 89 INCH-lbs.
Didn't make it to 70INCH-lbs.
***EDIT***I meant inch-lbs. Sorry...just a 1/4" drive.
Last edited by dewmanshu; Apr 25, 2007 at 07:46 PM. Reason: i put ft/lbs instead of in/lbs
Old Apr 25, 2007 | 07:33 PM
  #64
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
you mean in-lbs thats alot of tq on a tiny *** bolt
btw checks in the mail
Old Apr 25, 2007 | 07:37 PM
  #65
dc_justin's Avatar
Hello Dave
OUCH. That is painful...
Old Apr 25, 2007 | 07:39 PM
  #66
dewmanshu's Avatar
yep
Old Apr 25, 2007 | 07:59 PM
  #67
trever1t's Avatar
2nd fastest 5.3 ECSB
That makes me from here
Old Apr 25, 2007 | 08:04 PM
  #68
dewmanshu's Avatar
I don't know the grade or what they are besides 10mm. They have a core of some sort.
Old Apr 25, 2007 | 08:09 PM
  #69
trever1t's Avatar
The grainy look "core" is what hardening does to steel, changes the structure. Plating can cause the steel to become brittle.
  #70
1SlowHoe's Avatar
Destroyer of Transmissions
Just put some RTV over the hole!
