Finally nice weather-RADIX 90MM/60# Injector mod in the back yard
#62
Originally Posted by Wilde Racing
Don't tell me you've thrown more parts on before fixxing a problem....
The throttle body look HUGE..
It's like maggie had intentions of putting on a larger TB. The flange around the opening cuts out and the "tunnel" of the tube is perfect. 90MM.
Oh, before I forget to mention it...Grippy once was made fun of for noticing an "edge" in the inside turn of the j-tube. IT'S HUGE. It definitely needs to be grind down IMO. But not by me, I am too lazy.
#63
besides I still need the replacement intake bolt...to replace the bent one...ONE MORE BOLT to tighten to 89 INCH-lbs.
Didn't make it to 70INCH-lbs.
***EDIT***I meant inch-lbs. Sorry...just a 1/4" drive.
Last edited by dewmanshu; Apr 25, 2007 at 07:46 PM. Reason: i put ft/lbs instead of in/lbs
