Finally nice weather-RADIX 90MM/60# Injector mod in the back yard
#61
How do I change this text
Originally Posted by dewmanshu
I had pcm problems before I started all of this.
![turd](https://www.performancetrucks.net/forums/images/smilies2/turd.gif)
The throttle body look HUGE..
![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
#62
Originally Posted by Wilde Racing
Don't tell me you've thrown more parts on before fixxing a problem....
It's like maggie had intentions of putting on a larger TB. The flange around the opening cuts out and the "tunnel" of the tube is perfect. 90MM.
Oh, before I forget to mention it...Grippy once was made fun of for noticing an "edge" in the inside turn of the j-tube. IT'S HUGE. It definitely needs to be grind down IMO. But not by me, I am too lazy.
#63
besides I still need the replacement intake bolt...to replace the bent one...ONE MORE BOLT to tighten to 89 INCH-lbs.
![](https://i80.photobucket.com/albums/j188/dewmanshu/8e6b2e97.jpg)
Didn't make it to 70INCH-lbs.
![](https://i80.photobucket.com/albums/j188/dewmanshu/6e78f1ad.jpg)
***EDIT***I meant inch-lbs. Sorry...just a 1/4" drive.
![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
![Barf](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_barf.gif)
Last edited by dewmanshu; 04-25-2007 at 07:46 PM. Reason: i put ft/lbs instead of in/lbs
