It finally died, lm7 mp122 -11 psi
Old Jul 29, 2018 | 06:53 PM
trxmxzx's Avatar
13 Second Truck Club
Default It finally died, lm7 mp122 -11 psi
well as title says, early this year I changed oil which looked a little metaliky, ran mobile one instead of my normal Amsoil -
been chasing high IAT temps- power drop since different pulley, 6degrees of timing 11.4 afr.
Any how did a low rpm high boost pull earlier on the way to store and lost oil pressure 3200rpm @10 lbs
truck shook pretty good let out to notice 20lbs oil pressure - within 4 miles it was down to 10lbs
at 2000 rpms
silver metal flakes on dipstick when I checked at store- got towed home - hoping to save the cam shaft- doubt it though
Old Jul 29, 2018 | 07:46 PM
ZO6Ted's Avatar
Bummer however it's just an excuse for an upgrade. Life will be good again at some point
Old Jul 29, 2018 | 08:04 PM
trxmxzx's Avatar
for only putting down 407 whp @ 8psi
im thinking I could make a fun lq9/243 heads decent cam make similar power with it being all motor-
Old Jul 30, 2018 | 05:42 AM
MrHorsepowerLSx's Avatar
11 Second Club
you can make that power NA with an LQ9/243 combo. I made 403hp/419tq. With baby cam in my motor and a 60e 4 years ago
im sorry to hear that the motor crapped the bed, I hope you can salvage all your parts
Old Jul 30, 2018 | 08:40 AM
trxmxzx's Avatar
thanks man, me too
just undecided on cam selection now- if the tr220 didn’t die with it I may use that
good to know lq9/243 will put me in similar area, what size cam?
Old Jul 30, 2018 | 10:30 AM
arthursc2's Avatar
I'd keep the blower. Peak power might be the same, but torque curve will never match what you have now.
Sucks that it popped. I am chasing some **** on my L67 Buick right now and it might need a motor too. All in due time you'll have her up an cruising again
Old Jul 30, 2018 | 10:32 AM
ZO6Ted's Avatar
LQ4/9 with the blower?
Old Jul 30, 2018 | 11:32 AM
11 Second Club
thanks man, me too
I had a tsp 224/228 .581/.588 114 lsa
I also picked up a bunch of power after I went from a single 3” to a dual 3” setup that dumped before the axle
Old Jul 30, 2018 | 01:15 PM
trxmxzx's Avatar
been thinking about it but I don’t have the 317 heads anymore, just the 243 and if I recall the comp was 11.1:1 or close to that- I’ve read some have ran boost with it being that high on ls2 cars
curoius to what really failed- hoping to dig into it within the week to see -
Old Jul 30, 2018 | 01:18 PM
trxmxzx's Avatar
i was looking at that tsp 228
you gained a lot ? From exhaust change, I’m LT W/ORY to single stock 2.75 to 3” again over axle
never changed it from my old n/a setup but had plans to put a 3.5 duramax exhaust on just never had time to install it
