finally boosted but....
Old Nov 7, 2013 | 07:30 PM
  #91
TURBHOE's Avatar
i couldn't find it, did you say you were stock returnless style fuel setup or did you go to a return style setup? and does your tuner know how your fuel system is setup? the tune is different for both styles.
Old Nov 8, 2013 | 06:24 AM
  #92
darnie's Avatar
Im running a returnless set up for now. Untill i can save up to get the stuff for the return. Im running the walbro 400 with hotwire kit and Siemens 80lb injectors my psi at idle right now is 69-70 to my knowledge thats high. I think we plan to tune fpr 6-8psi for now till i can get the FPR set up
Old Nov 8, 2013 | 06:54 AM
  #93
darnie's Avatar
Your injector issue sounds like what my trucks doing now. I boughr them used fron a guy on here so i dont know if he had any issues with them or not. Wouldn't think so...? Im running 3" piping on the cold side tho.
Old Nov 8, 2013 | 09:53 AM
  #94
GMCtrk's Avatar
Way to high of idle fuel pressure, you're tune is going to be way off. Do you have a wideband on this thing?
Old Nov 8, 2013 | 10:13 AM
  #95
gamble686's Avatar
Yeah he does, usually reads very lean at idle and eventually settles down to stoich after the fuel trims go positive.
Old Nov 8, 2013 | 10:21 AM
  #96
kelsey_canard's Avatar
Before we go any further, has this truck ever been tuned? If so, who is the tuner?
Old Nov 8, 2013 | 02:00 PM
  #97
smokeshow's Avatar
Mod with training wheels
Man this thing sounds like a nightmare. I preach this almost daily...quality in, quality out. If you miss something either because of negligence or you simply missed important stuff by accident, it isn't going to give you good results.
How do the fuel trims compare between banks? If the fueling is erratic as hell it could be an issue with dirty injectors. I've been seeing this more and more often lately. There are few problems of this nature that can be fixed quickly. If you end up bringing the truck to me and I find mechanical problems, it will probably be a 2 week setback at least. And I don't want to waste your time or mine.
Old Nov 8, 2013 | 07:57 PM
  #98
darnie's Avatar
as far as i know there should be any mechanical issues, like stated the truck ran fine before this swap. the intake and heads never came off.
the injectors were swapped and then the turbo as well. im not to sure of the fuel trims the logs we have on the post prior to this? honestly it has to be something in the fuel/injectors or the tuning i have 2 different map sensors ive tried as well as 2 different tunes one being 20% more fuel. ive gone over the whole top of the motor about 7-8 times with starting fluid and could find a leak?
Old Nov 9, 2013 | 02:41 PM
  #99
Choda's Avatar
did you buy new injectors? if they are used by u or someone else, get them cleaned. I know New Era can do it, ive seen their fancy machine. =]
Old Nov 10, 2013 | 08:51 AM
  #100
darnie's Avatar
Yea i bought them used. But thats a good idea. I think its around $50 and they clean and flow test rhem would be a good peice of mind and if there is one bad then i can know whatvone and just buy one plus could make it alot easyer for jake. Thanks man. Appricate it
