a few questions
i have an 03 sierra with a frt mount turbo i run about 15 lbs of boost. i have a few simple questions
i have a meth injection kit and have been running washer fluid. where can i buy methanol? and what ratio should i mix it at?
I am going to replace my plugs this week i have been running tr6 ngk's. can i run e 3 plugs and would there be a benefit to using them?
i had another question but i forgot i will remember it later
thanks.
thanks.
GFYS and STFU
Mix is dependant on what your primary concerns are for it. If it's more for cooling than do 50/50 if it's simply for detonation prevention than stick to 100% meth. Just don't change your mix after you get it tuned for it, and if you do then get your truck retuned.
