a few questions
Old Aug 20, 2010 | 09:30 PM
bad cutt's Avatar
Default a few questions
i have an 03 sierra with a frt mount turbo i run about 15 lbs of boost. i have a few simple questions
i have a meth injection kit and have been running washer fluid. where can i buy methanol? and what ratio should i mix it at?
I am going to replace my plugs this week i have been running tr6 ngk's. can i run e 3 plugs and would there be a benefit to using them?
i had another question but i forgot i will remember it later
thanks.
Old Aug 20, 2010 | 09:47 PM
quicksilverado's Avatar
Do not use e3 plugs. You can get meth at most performance shops. Run straight meth then you don't have to worry about mixing it and getting your mix ratio perfect.
Old Aug 20, 2010 | 10:37 PM
MikeGyver's Avatar
Originally Posted by bad cutt
... can i run e 3 plugs and would there be a benefit to using them? ...
The only benefit would be E3's, by getting your money. Use TR55 plugs.
Originally Posted by quicksilverado
... You can get meth at most performance shops...
Or drag strips.
Old Aug 21, 2010 | 12:14 AM
Spoolin's Avatar
GFYS and STFU
Mix is dependant on what your primary concerns are for it. If it's more for cooling than do 50/50 if it's simply for detonation prevention than stick to 100% meth. Just don't change your mix after you get it tuned for it, and if you do then get your truck retuned.
Old Aug 21, 2010 | 07:56 AM
03_Denali's Avatar
Meth is also at home depot, lowes, ace hardware...etc
Old Aug 21, 2010 | 08:23 AM
TURBHOE's Avatar
I've read that it's at lowes and what not but never seem to find it there.
Old Aug 21, 2010 | 10:18 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Home Depot? really? That would be cool if true.
Spoolin said it right, run straight meth to allow more timing
Old Aug 22, 2010 | 11:31 AM
bad cutt's Avatar
i looked at menards home depot and lowes and couldnt find meth
Old Aug 22, 2010 | 11:57 AM
Quik's Avatar
5 year bitches!
denatured alcohol
Old Aug 22, 2010 | 03:25 PM
03_Denali's Avatar
what quik said.. look in the paint department. It's like $15 a gallon
