F1a with house of boost bracket info please help
Old Apr 6, 2016 | 01:16 AM
murderedSS's Avatar
Default F1a with house of boost bracket info please help
Just a quick question I got a f1a with hob bracket and all I need is the ati balancer can any one help me with a part number I will be running it on my lq9 the Procharger comes with the 8rib pulley I need to bolt to the ati balancer just not sure which one
Old Apr 6, 2016 | 05:06 AM
blown02408's Avatar
02 w/ lowest mileage 2800
917286 is the one you want
Old Apr 6, 2016 | 06:30 AM
03sierraslt's Avatar
Do they make a overdriven one?
Old Apr 6, 2016 | 10:25 AM
murderedSS's Avatar
Thanks blown that's what I thought but wanted someone to verify
Old Apr 6, 2016 | 01:03 PM
blown02408's Avatar
If you mean the balancer itself, then yes, in 8 and 10 rib. I don't have the catalog in front of me right this second, but if you would like the part numbers I can look them up later for you.
Also, in case anyone didn't know the dampers that they make for a 2010 camaro will also fit a truck.
Old Apr 6, 2016 | 02:29 PM
LongBlue's Avatar
Have a HOB kit too. 12 rib crank pulley for the ATI damper is for a 2010 Camaro from Procharger and I believe is 7.63" in diameter. Don't know about a larger diameter crank pulley. Maybe contact HOB.
Old Apr 6, 2016 | 08:02 PM
blown02408's Avatar
Does the 12 rib pulley from HOB have 3 or 6 holes in it? Another option is the camaro pulley with the 6 bolt pattern part number 918635.
Old Apr 6, 2016 | 08:10 PM
blown02408's Avatar
Ati 8 rib overdriven damper part numbers-
6%OD 7.96 Dia. 917107
10%OD 8.235 Dia. 917108
Old Apr 7, 2016 | 03:07 PM
LongBlue's Avatar
3 bigger holes, 3 little holes. See pics.
Old Apr 7, 2016 | 03:09 PM
LongBlue's Avatar
