Engine rebuild before turbo?
Old Apr 12, 2013 | 06:49 PM
  #21
white4.8l's Avatar
Registered User
All good to know thank you all!.
Old Apr 12, 2013 | 08:41 PM
  #22
white4.8l's Avatar
Registered User
I did hear that i should regap my piston rings is that a must or how much am i limited too?
Old Apr 16, 2013 | 05:02 PM
  #23
dont know the limitations of stock gap,but in my situation i know i may want more boost later, the engine is out so i will be gapping top ring.
google big bang theory its ls build.
Old Apr 16, 2013 | 08:52 PM
  #24
white4.8l's Avatar
Registered User
How would you gap the rings? Just buy new ones?
Old Apr 17, 2013 | 04:11 AM
  #25
TURBHOE's Avatar
Pop out the pistons pull off the rings, gap them and put them back in.
Old Apr 17, 2013 | 09:01 AM
  #26
lycominghunter's Avatar
white 4.8, I am doing a similar build at the moment. My engine has 165k so I'm not too worried about going all out with the supporting mods for now because I plan on building a larger engine at a later date. For right now, I'm doing a isky triple 12 cam with isky springs. I plan on running 10-12 psi in hopes of 500 or so hp and I don't plan on revving the **** out of it. I also think that its probably a good idea to change the timing chain and gears, theyve been known to bust.
Old Apr 17, 2013 | 05:21 PM
  #27
white4.8l's Avatar
Registered User
Ok im doing a 68mm turbo with about 60lb injectors looking for 500 to 600 hp and behond later. ls9 headgaskets, new piston rings and gapping them, because my engine has 218k on it, and valve springs. Not sure what valve springs i need. Also i need to know where is the best place to put my oil feed line to the turbo? All help and pictures greatly appriciated. Thank you!
5.3Okasai
Mar 9, 2022 01:07 PM
lxcoupe
Jul 27, 2015 08:19 PM
4B11T
Jul 13, 2015 03:48 PM
Cowboy17
Jul 9, 2015 08:22 PM
Mzay
Jul 6, 2015 11:03 PM
