engine life vs power
Old Jun 21, 2009 | 09:09 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default engine life vs power
okay so im currently NA
i was thinking about running a " rear mount" at the y pipe with keeping my LT's.. sayy.. 7ish psi...
can my motor handle the boost?.. stock 07 5.3... i wil prolly put some 317's and a turbo cam if i want to do about 10psi
Old Jun 21, 2009 | 09:17 PM
BlownChevy's Avatar
blownerator
25 Year Member
If you are going to go turbo, do a front mount......
Old Jun 21, 2009 | 09:27 PM
thunderwagen's Avatar
+1 on the front mount. Trick to the right---->
Old Jun 21, 2009 | 09:57 PM
Coban's Avatar
It will handle the boost just fine. I'm running 10psi on a cammed stock 5.3 with bigger injectors. Its all in the tune.
And yes, just do the front mount.
Old Jun 23, 2009 | 10:27 AM
05stepside's Avatar
Sounds like my setup exactly. I have a 05 5.3 with 317's and a turbo cam pushing 10psi. I have the pacesetter headers and ORY then turbo with a 4" down pipe. It'll work fine
Old Jun 23, 2009 | 10:49 AM
fastnblu's Avatar
Why?
Brian, I'm surprised u didn't even mention a Magnacharger.
Old Jun 23, 2009 | 12:39 PM
ForcedTQ's Avatar
Lightbulb
Originally Posted by fastnblu
Why?
That Magnacharger reference is implied when he said "If you're going to go turbo",
JFWY BC.
Old Jun 23, 2009 | 10:47 PM
1BADAZZSS's Avatar
If your plannin on doin a rearmount be best to put the stock manifolds back on, helps keep heat in the exhaust, and use as much header wrap if possible back to the turbo. I am happy with my rearmount, no complaints here.
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
