E85 vs methanol injection
Old Apr 13, 2017 | 06:24 PM
nathanstowing's Avatar
Default E85 vs methanol injection
I'm running a single turbo on a lq9 nbs rbsb and looking for more power, what do you guys think is better between e85 and methanol ??
Old Apr 13, 2017 | 07:01 PM
FFDP's Avatar
How much power?
E85 could require an all new fuel system depending on power goal, figure you need 30-40% more fuel flow at least.
Old Apr 14, 2017 | 02:31 PM
I'm looking to get around 600-650 hp max
Old Apr 14, 2017 | 03:02 PM
LPCWS6's Avatar
I'm set up for flex and also have meth on my lq9. At 650hp max you should be fine with meth. I made 708 rwhp on 91 + meth with a single walbro 450 on a returnless fuel system. Like FFDP said when I wanted more hp and switched to flex I had to have my fuel system completely redone. I might be the only weirdo spraying Meth on E85 but my truck is set up to run whatever gas I feel like and go. I just can't go in my higher boost settings when I have 91 in the tank.
Old Apr 14, 2017 | 07:59 PM
FFDP's Avatar
Just use pump gas and meth if you want 600's.
Old Apr 15, 2017 | 04:23 PM
thanks guys methanol it is, what meth kit it good I'm planing on using my wiper reservoir for a slick look.
Old Apr 15, 2017 | 11:31 PM
LPCWS6's Avatar
I got a alkyl control meth kit. From what I have gathered it's the best and the only one that allows you to run 100% meth. The pump did crap out on me once and started leaking though.
Old Apr 17, 2017 | 08:48 PM
zachm89's Avatar
If you decide you want more capacity I have a 7 gallon snow performance tank just sitting around. Id let it go cheap
Old Apr 19, 2017 | 04:17 PM
thank you guys I'm leaning towards a snow performance kit stage 2
