Dyno'd the Radix'd truck today, these #'s good
Old Oct 25, 2005 | 11:00 AM
  #81
moregrip's Avatar
what a rush!
Originally Posted by zippy
no, no....your engine in say a stock regular cab would require the same fuel, yet show more hp at the rear wheels. shorter driveshaft, smaller and lighter wheels and tires, etc. for example if you dyno'd your av with your 22's and then dyno'd it with a set of lightweight 18's you'd show a higher rwhp number, yet you still sprayed the same amount of fuel through the injectors. conclusion, rwhp and fuel requirements don't always go hand in hand.
LOL, looks like I missed the boat at what you were trying to say, next time I'll just let you explain what you meant
anyway, my example is valid, just in a different sense, and not what Zippy was saying at all................I just started thinking parasitic loss and couldn't let go I guess...........all yours zippy
Old Oct 25, 2005 | 04:16 PM
  #82
zippy's Avatar
Originally Posted by Naked AV
Well that makes more sense then, because otherwise there would have to be different programming for vehicles based on weight.
So what are the variables that dictate changes in fuel requirements?
there are a few variables that are important for that. the important one's are a/f ratio required and airflow numbers. if you have an engine on the dyno that pulls in 55lbs min of air through the maf, that engine is going to have the same fuel requirements for the most part in any vehicle you put it in. the air/fuel ratio required is also another variable. a boosted engine is commonly happy around 11.4:1-11.7:1 a/f ratio which is going to require more fuel to achieve than say a naturally asperated engine of the same airflow numbers which is commonly happy around 12.4:1-12.7:1 a/f ratio. another issue is boost pressure. to get an equal amount of fuel to come out of the injector at 0 psi compared to say 10psi, you need about another 10psi or what happens is your xxlbhr injector now becomes smaller once you're into boost.
Old Oct 25, 2005 | 07:39 PM
  #83
CHarris's Avatar
Lots of good info in this and the preceding posts, Zippy. Thanks for taking the time.
As an illustration of the MAF flow vs injector deal... A truck maxing out a MAF (just frequency... not actual airflow) with a small engine (think 5.3)might do it higher in the rpm band... say 5600-5800 rpms for instance. My H2 (6.0) maxs out the MAF frequency in the 4500-4600 rpm range. That means I'm flowing a lot more air for a lot longer and working the injectors harder, too. Add in the fact that I can run 20 degrees of timing now for at least half track as long as I'm in the lower 11's for AFR and you should see that this combo takes a hell of a lot of fuel. I could run leaner if I wanted to run race gas... but I only run 1 tune that is for street and track. I don't switch. Running race fuel would consume less of a quantity of fuel in that case.
Old Oct 27, 2005 | 10:33 AM
  #84
LBSBLOWN's Avatar
btw, is this an L33???
Nope, its a LM7 5.3L, vin T
Old Oct 31, 2005 | 09:21 PM
  #85
white lightning SS's Avatar
Is the Magnacharger 255 pump and ford 42 lb/hr injectors enough to feed an LS1 w/ heads, cam and 10 psi in an 05 ecsb Z-71(flex) or will you still need more fuel. The internals are forged and the cam will run to 6500. will I have enough fuel w/ out the magnavolt? or should I buy it? motor (a.k.a money pit) is going in in a week or so and I dont want to wreck it. I also have changed to 88mm maf and 90mm LS2 throttle body. by the way I also need to feed a 75 hp wet nitrous shot off the rail port.
Old Oct 31, 2005 | 09:43 PM
  #86
1SlowHoe's Avatar
Destroyer of Transmissions
I would like to know this as well. I dont have the bigger MAF/TB but.....
Old Nov 1, 2005 | 07:28 AM
  #87
LBSBLOWN's Avatar
Originally Posted by 1SlowHoe
I have Ford 42#'ers AND a maganvolt in hand and, I just might get an inline 225lph pump just for giggles. Runnin out of fuel is bad, ask #7
1SlowHoe,
I just received my Magnavolt but it didn't come with any instructions.
do you have any and if so can you E-mail a copy to me.
I'm going to call Magnacharger as soon as they open but they all may be at the SEMA show today.
LBSBLOWN
Old Nov 1, 2005 | 08:21 AM
  #88
1SlowHoe's Avatar
I actually have the Kenne Bell one that magnacharger sold before they got there own. I guess the directions should be close. PM me your e-mail and I can send them that way. Photobucket is down right now.
Old Nov 1, 2005 | 08:38 AM
  #89
1SlowHoe's Avatar
Try this. See step 47
http://www.magnusonproducts.com/pdf/manual04.pdf
Old Nov 1, 2005 | 08:53 AM
  #90
LBSBLOWN's Avatar
Thanks
That link helps out a lot
wrb002
Aug 31, 2015 12:00 PM
USMCvet0311
Aug 13, 2015 09:59 PM
therock
Jul 25, 2015 09:23 AM
sTNT971
Jul 16, 2015 12:39 PM
black6spdz
Jul 16, 2015 01:32 AM
