Drop in HX tank for 07 up trucks.
Old Jun 18, 2016 | 06:31 PM
NORCAL TBSS's Avatar
Restricted User
Default Drop in HX tank for 07 up trucks.
Just finished install for my 16 whipple. Uses oem bracket and bolt to hold it in place. Clean little set up.
Instagram check out norcal_ss got bunch of mods in store for my whipple
Attached Thumbnails Drop in HX tank for 07 up trucks.-20160618_155923.jpg   Drop in HX tank for 07 up trucks.-20160618_155932.jpg
Old Jun 19, 2016 | 01:12 PM
terravast4's Avatar
looks good!!
Old Jun 19, 2016 | 01:15 PM
Choda's Avatar
How many gal? Where did you buy it? Stainless or alum?
Old Jul 22, 2016 | 06:36 PM
KB Silverado's Avatar
what clamps do you have on the coupler between the intake tube and TB?
Old Jul 23, 2016 | 12:07 PM
Restricted User
got them from silicone intakes.com and then powdercoated black
Old Jul 29, 2016 | 05:33 PM
8.1 HD's Avatar
Whose hx tank is that and how much does it hold. Looking to upsize and get more coolant flowing. tIA
Old Jul 29, 2016 | 08:56 PM
wuznme's Avatar
Saw one like it somewhere, it was like $899...I'll see if can find the site.
not sure same one...
http://www.d3peparts.com/product-p/d3pe-c7-a2wtank.htm
Old Jul 30, 2016 | 01:40 PM
Restricted User
It's under 200. Pm me
Old Aug 2, 2016 | 09:24 AM
Bluecobra's Avatar
Looks like the Canton tank I bought off Summit a while back. If it is, you will want to remove the filler neck and seal it with something like silicone, as when you get a little heat in the fluid it will **** out around that "seal". Mine did, and I called Canton to complain. They didn't care, just wanted to sell me their little tool to help hold the bolts on the inside of the tank when removing and sealing.
Why would anyone build a tank with a pressure relief and all, that won't hold pressure??? The folks at Canton could not answer that for me....///Rant off, sorry for the distraction.
Old Aug 23, 2016 | 05:45 PM
07Softail's Avatar
That's a MOROSO #63494 coolant tank for 05-10 mustangs
RT
