Downpipe help...
Im in the process of installing a cxracing 76mm turbo with a 1.15 A/R on my truck. Im rumning a set of kb-racing 3.5" down pipe. My only problem is the exhauat side of the turbo is measuring at 5" OD do they make something that will nexk it down so it will fit?
Idk how to describe it. The inside diamator is 3.5"but just lokt the down pipe. But the lip of the flange us 4.5" it looks as if a 4" clamp would possably fit. But it wouls still be bigger than the DP? I just got a new computer so we dont have internet at the moment so i cant post pictures.
I am pretty sure when vbands are listed, they are listed by the pipe ID only. The outer flange areas will be larger than its listed size. So if its a 3.5" ID, it should be a 3.5" vband. Since you already have the 3.5" DP, why dont you just put them up to each other and see if they fit...
^ yea just hold it up to the turbo and look at it. Just make sure the difference between the flange and the lip of the flange on both the turbo and DP are the same or it won't seal properly.
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Jan 27, 2016 11:45 AM
noproblems209
Aug 10, 2015 06:57 PM
