Downpipe help...
Old Jun 15, 2013 | 07:39 PM
darnie's Avatar
Default Downpipe help...
Im in the process of installing a cxracing 76mm turbo with a 1.15 A/R on my truck. Im rumning a set of kb-racing 3.5" down pipe. My only problem is the exhauat side of the turbo is measuring at 5" OD do they make something that will nexk it down so it will fit?
Old Jun 15, 2013 | 10:42 PM
GONEB4U's Avatar
10 Second Club
I don't think you will find an adapter to neck your turbo up to a 5" and still fit properly. You will probably have to get another DP or step up your game with a bigger turbo.
Old Jun 15, 2013 | 10:45 PM
darnie's Avatar
Ya, thays kinda what i was afraid of. I just didn't know if there was something out there that would neck it down
Old Jun 15, 2013 | 11:31 PM
darnie's Avatar
Ok i stand corrected the OD of the nack of the turbo is 4.5"down and the ID is 3.5 "
Old Jun 15, 2013 | 11:57 PM
Atomic's Avatar
I have a gauge for that
If its the garret flange style a 3.5" vband should work.
Old Jun 16, 2013 | 09:07 AM
darnie's Avatar
Idk how to describe it. The inside diamator is 3.5"but just lokt the down pipe. But the lip of the flange us 4.5" it looks as if a 4" clamp would possably fit. But it wouls still be bigger than the DP? I just got a new computer so we dont have internet at the moment so i cant post pictures.
Old Jun 16, 2013 | 09:56 AM
Atomic's Avatar
I am pretty sure when vbands are listed, they are listed by the pipe ID only. The outer flange areas will be larger than its listed size. So if its a 3.5" ID, it should be a 3.5" vband. Since you already have the 3.5" DP, why dont you just put them up to each other and see if they fit...
Old Jun 16, 2013 | 02:20 PM
Alpinestar's Avatar
^ yea just hold it up to the turbo and look at it. Just make sure the difference between the flange and the lip of the flange on both the turbo and DP are the same or it won't seal properly.
Old Jun 16, 2013 | 07:18 PM
darnie's Avatar
Ill have to see if i can get a picture on here some how. I get what your saying. But the lips alot bigger than the Downpipe
GXPJAY
Feb 13, 2022 08:15 AM
GMCtrk
Oct 20, 2015 06:17 AM
97_ek
Sep 23, 2015 09:16 PM
noproblems209
Aug 10, 2015 06:57 PM
