Done deal.. Maxed out 4.8L/76mm Magnum. Next?
Old Sep 24, 2012 | 09:55 PM
foose04's Avatar
18psi/50 shot made 730/747. Truck best track time is 6.52/106.6. Weighed it two weeks ago at Carolina Dragway, with me it is 4550.
Old Sep 24, 2012 | 10:02 PM
smokeshow's Avatar
Mod with training wheels
How high is your timing?
Old Sep 24, 2012 | 10:04 PM
foose04's Avatar
16.5 above 6K
Old Sep 24, 2012 | 10:05 PM
beastmode's Avatar
Import Moderator
I seem to remember coming across a thread of you building a forged 5.3... is this still in the works?
Old Sep 24, 2012 | 10:14 PM
foose04's Avatar
Yeah forged aluminum 5.3 is next up. Haven't got to far with it yet though.
Old Sep 24, 2012 | 10:16 PM
Quicklynx's Avatar
How high did you get with the LS6 cam? What heads are you running?
Old Sep 24, 2012 | 10:21 PM
black00chev's Avatar
Slowest turbo build ever!
You were running through a 3'' DP and cutout on these runs right? I wonder if going to a 3.5-4" DP would help any.
Can you change just the turbine wheel and housing somehow?
Old Sep 24, 2012 | 10:40 PM
foose04's Avatar
That was with ls6 cam and still on stock heads.
No options there, better off changing turbo all together.
As for dp, I hate to spend a couple hundred dollars and have the same issue and then have cut it off to run a different 4" outlet turbo. Current setup is 3" into cutout.
Old Sep 24, 2012 | 10:51 PM
nonnieselman's Avatar
Yea i vote something with ~ 83mm wheel. Be amazed how much better power it can make.
Give it a go!
Old Sep 24, 2012 | 10:55 PM
Well if you're making this power with a 3" DP through a cutout a bigger DP most likely wont do much then.
I vote for this badboy right here!
http://www.precisionturbo.net/Street...GT42-Style/282
