Done deal.. Maxed out 4.8L/76mm Magnum. Next?
#142
Well since I'm still on a 2 bar, it is nice to not need 21-22psi. It's hard to judge though as I haven't been able to go thru the RPMs at a set boost. Just a crazy ramping boost rate lifting at 5k area.
The billet 76 is a winner I'm sure. I had he normal 7675, but my tuck wasn't as well setup then but I could control boost with that turbo. This BW I can't even come close to controlling it.
#145
What turbo blanket you guys running on these with the t4 housing? I know first thought is a T4 blanket with t4 turbo, but it seems the over all size of this 1.10 is closer to a T6 size blankets.
Thoughts or pictures please!
#146
I use a cheap ebay T4 turbo on my T6...it doesnt cover the whole thing, but for $50 its hard to argue with. My infrared temp gauge says it only gets up to 200-250, which is awesome considering the turbine housing is 1000+. If I can get that out of a $50 blanket, I would never be able justify some of the $200+ ones out there.
#149
Thanks for the info guys.
I been away on work, but when I get home I plan to do something with the wastegate setup so I can actually get on it. There is a Dyno Day at a local shop at the end the month, i'd like to be dialed in and ready for it.
#150
I got my new T6 ebay blanket in the mail today, heres some comparison shots to my T4 ebay blanket...
The T4 one actually fits better than the T6 one for my 1.25 T6 housing.
I figure the smaller the gate the less waste
