Do the ring gaps need to be opened...E85 non intercooled???
Old Apr 21, 2015 | 04:46 AM
gols1go's Avatar
Default Do the ring gaps need to be opened...E85 non intercooled???
I am building a front mount 5.3L in a S10. The turbo is an On3 78/75 and I want to run E85 non intercooled. Looking to run 12-15#'s. Just wanted to ask some guys with experience if it would be worth opening the ring gaps. I know E85 cools the combustion temps, but running without an intercooler I could see air in temps between 2-300°F. Open to suggestions as to what you have seen work....
Old Apr 21, 2015 | 06:50 AM
Gadgetized's Avatar
I would open up the gap if it were me. The stock pistons are not very forgiving if the rings touch. I had a supercharger on pump gas at 12 PSI and had the rings touch. That was a bad day.
Old Apr 21, 2015 | 07:39 AM
tim wellington's Avatar
Default gap
open them up .if you running factory pistons i would for sure 15 psi is alot with out intercooler
Old Apr 21, 2015 | 09:42 AM
George C....'s Avatar
Formerly ScreamingL
Depending on mileage of motor you use the gap may already be opened up
Non-intercooler may not be great idea
Old Apr 21, 2015 | 10:15 AM
Atomic's Avatar
I have a gauge for that
If the engine has less than 150k, yes open them up, and figure out a way to run an intercooler.
Old Apr 21, 2015 | 11:37 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Proper ring gap for any specific application is just as important as bearing clearance. Are you a gambling man?
Old Apr 21, 2015 | 08:17 PM
black4.8's Avatar
is it a good idea? yes. would i bother? no. junkyard sells them everyday. i've been 5 years of 15# or more.
Old Apr 21, 2015 | 08:28 PM
Formerly ScreamingL
Yes but 15lbs from a small turbo isn't same as larger turbo
24-25 psi on stock motor here ........
Ring gaps .028/.028
Old Apr 22, 2015 | 01:01 AM
gols1go's Avatar
So running the intercooler seeks to be the best bet. What size wastegate are you running with the turbo log setup?
$A_Money$81
Mar 27, 2023 10:25 AM
OHsixLS3
Nov 22, 2015 07:45 PM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
trxmxzx
Sep 29, 2015 07:42 AM
