DO i need or have 2 have a BOV?
Old Jun 21, 2006 | 04:51 PM
quicksilverado's Avatar
Originally Posted by Wilde Racing
That was my bad. I was thinking that my BOV didn't work after I moved the ref line to the intake for the waste gate. I just remebered the my BOV was full of water/ meth and that was the cause of it not working.
I edited my first post.
I was'nt saying you did something wrong. Just wondering how to hoo the bov into the system so it will work properly.
Old Jun 21, 2006 | 06:37 PM
Wilde Racing's Avatar
How do I change this text
Well, I'm going to move my waste ref line to the other side of the throttle blade. I think, when the throttle closes and the waste gate "sees" vac, it opens befoe the BOV.
Old Jun 22, 2006 | 08:25 AM
Mort's Avatar
Cool
Vacuum should close the wastegate not open it. Boost pressure is used to open the wastegate and bypass the turbine so that boost at the intake manifold is controlled to a pre set maximum. I think if anything that any vacuum will close the wastegate.
I do have my boost reference for the wastegate run off the compressor scroll so mine may work a little differently than yours does because my wastegate will never see any vacuum.
Old Jun 22, 2006 | 05:11 PM
kenihemi's Avatar
There is one other thing to consider; If for some reason there is a problem with the wastegate such as it sticks and won't open or one of the vac lines is blocked (that happens with remote mounts in cold climates) the boost will just climb until one of the 2 happen.
Worst case; A video of parts of your engine coming out of the hood or fenders gets posted on the internet.
Best case; Your blow off valve opens and doesnt allow the pressure any higher than its setting that should be a safe setting depending on your application.
Its a cheap way to buy a safety fuse to prevent a problem like that.
Old Jun 22, 2006 | 07:01 PM
TG02Z71's Avatar
It worked fine until I move the bov and had to extend the hose. Well at least I can't hear it any more. Here is what it looked like before
BOV Video
Nice!
Don't tell me you strapped your video camera under the hod?!?!?
Thanks for posting that up man!! seriously.
Old Jun 23, 2006 | 12:25 AM
Originally Posted by TG02Z71
Nice!
Read post 17
Old Jun 23, 2006 | 05:42 PM
ogkevin13's Avatar
Banned
where can i buy a bov for an sts set up besides buyin it from sts (2001 silverado 5.3)
JordanH
Feb 19, 2019 07:46 AM
03chevytruck
Nov 7, 2016 04:43 PM
Tuckin15s
Sep 23, 2015 09:35 PM
97_ek
Sep 23, 2015 09:16 PM
6.0l RST
Jul 7, 2015 02:22 PM
