Dmax intercooler is on the way
#21
i looked at a 2006 and they have a plstic end cap on the one end maybe both but the one i have is solid aluminum. but they "should" work the same but i don't know that they will lol. mine is an '04
#22
If i remember correct he said it was a 2002 or 2003. Im gettin pretty excited about making this work, even more excited that im going to save about $1100 by not getting the whipple cooler.
#26
Originally Posted by Mikegyver
Get HP Tuners. You can do other stuff with it, too.
#27
where ever you iat sensor thats what you'll read. if its hooked to your ecu. if you didn't relocate it then it will be in your maf and will read the air comming through there but if you move it it will read where ever you moved it to.
#28
I moved mine to my manifold, and the readings I was getting show that I might have been heat soaking it, the cruise temperatures were 150 to 170 degrees at about 85 degrees ambient.
After I get it running with the intercooler, if the IAT still reads high, I will relocate the sensor to the I/C tube entering the engine.
#29
okay, the saga continues. My radiator is 44.5" wide (including endtanks)!! Basic translation: No eff'n way my radiator will fit between the inlet/outlet of the intercooler. So it looks like I am going to have to get a Dmax radiator as well. This may slow things down a little, but i will get it. I will also most liely just pick up a stock auxilary transmission cooler to act as my engine oil cooler since the Dmax radiator has none built in. The fun continues.
