Dmax intercooler is on the way
Old May 22, 2006 | 03:08 PM
  #21
TURBHOE's Avatar
i looked at a 2006 and they have a plstic end cap on the one end maybe both but the one i have is solid aluminum. but they "should" work the same but i don't know that they will lol. mine is an '04
Old May 22, 2006 | 03:19 PM
  #22
Whippled 496's Avatar
If i remember correct he said it was a 2002 or 2003. Im gettin pretty excited about making this work, even more excited that im going to save about $1100 by not getting the whipple cooler.
Old May 22, 2006 | 04:14 PM
  #23
TURBHOE's Avatar
yeah as long as i goes together right i think it will get the job done nicly. i just wish i had the money to finish my turbo up.
Old May 23, 2006 | 02:12 PM
  #24
What is the best method to measure my IAT's? I want some before and after comparisons.
Old May 23, 2006 | 02:25 PM
  #25
MikeGyver's Avatar
Get HP Tuners. You can do other stuff with it, too.
Old May 23, 2006 | 02:34 PM
  #26
Can that measure my blower outlet temps? I thought i could only measure my MAF readings with that.
Old May 23, 2006 | 06:11 PM
  #27
TURBHOE's Avatar
where ever you iat sensor thats what you'll read. if its hooked to your ecu. if you didn't relocate it then it will be in your maf and will read the air comming through there but if you move it it will read where ever you moved it to.
Old May 23, 2006 | 08:24 PM
  #28
MikeGyver's Avatar
And "moving it" consists of buying a new one (from a Camaro or 'Vette), and cutting and splicing the MAF's IAT sensor wires.
I moved mine to my manifold, and the readings I was getting show that I might have been heat soaking it, the cruise temperatures were 150 to 170 degrees at about 85 degrees ambient.
After I get it running with the intercooler, if the IAT still reads high, I will relocate the sensor to the I/C tube entering the engine.
Old May 25, 2006 | 07:26 AM
  #29
okay, the saga continues. My radiator is 44.5" wide (including endtanks)!! Basic translation: No eff'n way my radiator will fit between the inlet/outlet of the intercooler. So it looks like I am going to have to get a Dmax radiator as well. This may slow things down a little, but i will get it. I will also most liely just pick up a stock auxilary transmission cooler to act as my engine oil cooler since the Dmax radiator has none built in. The fun continues.
Old May 25, 2006 | 10:29 AM
  #30
TURBHOE's Avatar
just think of the cooling capacity you'll have. lol
