DBC 102 Throttlebody
Old Jul 31, 2017 | 03:56 PM
BigKID's Avatar
I have been leaning toward the ebay tb's myself. A throttle body is a very simple device and I have a hard time justifying $500+ for the NW, Holley, Accufab units. However, if I were to spend a premium on one, it would be the Holley or Accufab 105MM.
I ran into the idle issue on the KB with a 95mm PTM after I got the vacuum leak fixed. The blade is cracked as far as the TPS sensor will allow and still have a cold start and low speed zero throttle-idle transition issue.
Old Jul 31, 2017 | 05:47 PM
03sierraslt's Avatar
Do the eBay throttlebody's have idle bleed screws?
Old Jul 31, 2017 | 05:51 PM
Since we are discussing it.
http://documents.holley.com/199r10672-1.pdf
Old Aug 1, 2017 | 12:10 AM
Atomic's Avatar
I have a gauge for that
Thats basically just another bleed port with a small adjustable valve. Same effect as increasing the idle set screw on the tb, except it doesnt move the blade. Pretty neat, but not needed 95% of the time. I have actually never seen that before even on the NW TB I used to have.
Old Aug 1, 2017 | 03:58 AM
Timz had cold start issues with his and I adjusted his, he had a Fast I believe and it worked like a charm. It allowed me to get his IAC counts in range so it could actually adjust up and down as needed.
Old Aug 1, 2017 | 09:36 AM
Last Call's Avatar
TOTM: January 2007
On some of the EBay TB's. as you open the blade, it will actually block some of the IAC passage opening restricting airflow. If opening the passage and adjusting the set screw don't allow enough airflow at cold start and IAC trimming at hot idle, a hole may be required. I know that is in a debate in itself.
Old Aug 2, 2017 | 10:06 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
look around on LS1 tech theres not many if any people that have had any luck with the cheapo ebay TB I've got a 105mm holley and a NW and the holley is a much nicer piece
Old Aug 3, 2017 | 01:30 PM
TrendSetter's Avatar
ive run two of the ebay ones. the first one required some mods to get the iac installed but worked fine after that on a ls2 with ls3 heads and big cam. the second one didnt require anything and i used it on a turbo 4.8 and twin turbo 5.3 with zero issues.
i got all kinds of flak just last week here for recommending them, but a tb is pretty simple and the $90 ones work very well in my experience.
Old Aug 3, 2017 | 02:22 PM
Atomic's Avatar
Yep, like I said mine is working just fine.
Old Aug 3, 2017 | 06:09 PM
Last Call's Avatar
TOTM: January 2007
Are you opening the IAC passage more or opening the bore of the blade to allow more air in around the blade?
