d1sc question
okay, i ordered my kit and i was told that the 44# injectors would be good for what i was trying to do, and that the 04sss does not need a fuel pump upgrade. this does not sound right to me.what do you guys think?
future mods may be a cam. should i just get a walbro 255 any way?
If you are switching to the 44's you should also up the pump?? Unless they are giving you the fuel ref kit with the kit.. How many psi do you plan to run with it??? At a minimum put a 255 on the rail. All though with the truck being a 6.0, if you decide to turn up the boost down the road, you might even have to up the injectors
not sure on boost levels. i was hopeing to get at max 8-10 psi here in colorado, not sure if anymore than that would be safe on a stock bottom end. i was also told the first 3# of psi is basicly obsolete at this altitude.
any ideas?
any ideas?
murderedSS
27
Oct 12, 2015 11:13 AM
iregret
Sep 7, 2015 01:20 PM
