Crazy boost problem!!!!!
Old Jun 1, 2010 | 09:35 PM
04gibbstahoe's Avatar
Default Crazy boost problem!!!!!
Ok, so up until a few weeks ago I was running a 3.3" pulley on my MP112 and making 8 lbs. of boost and everyhing was great. I decided to do a cam swap and went with a 220/226 xer lobes on a 114 lsa. Finished the cam swap and lost 3 lbs. of boost. Went to the track last Friday and went 13.70 @ 99. Before the cam and SC3000 cnverter I went 13.62 @ 99. So I actually went a little slower with the new cam on less boost. So yesterday I decided to pulley farther down to a 3.1" and get my boost back to where I was before the cam swap. STILL ONLY SHOW 5 lbs! What the hell is going on????? I can understand losing some boost with the cam swap whether it be from too much overlap or flowing more air or whatever, but adding a smaller pulley and still not gaining boost back! I am so confused............. Any help is appreciated.
Old Jun 1, 2010 | 09:37 PM
BlackGMC's Avatar
Resident Retard
belt slip or your crank spinning?
Old Jun 1, 2010 | 09:43 PM
Crank is pinned! Belt slip, maybe........... I am using a 112" belt. The boost does not jump up and down like a slip would. It holds strong a 5.
Old Jun 1, 2010 | 11:55 PM
BigRed Cummins's Avatar
Not trying to ask a dumb question, but has it been re-tuned with the new cam?
Old Jun 2, 2010 | 12:14 AM
Atomic's Avatar
I have a gauge for that
what valve springs are you using and whats the lift on the cam?
Old Jun 2, 2010 | 06:58 AM
old motorhead's Avatar
I think you'll have to pulley down a bit more to see 8psi with that cam. I needed a 2.8" pulley on a similar rig with 220/220 .581 115LSA cam to see 8+ psi.
Old Jun 2, 2010 | 07:50 AM
OLD NO.7 Avalanche's Avatar
I also put on the 2.8" pulley for the bigger boost. (8+).Another question, did you change springs and pushrods when you swapped the cam? #7
Old Jun 2, 2010 | 08:11 AM
Cam is .581/.585 lift. I use the patriot gold dual springs. And, yes I did have it retuned after the cam.
Old Jun 2, 2010 | 08:49 AM
bluchev's Avatar
sounds like you shouldve bought a Whipple.....
GMCtrk
Dec 18, 2015 04:47 PM
slowmo934
Sep 9, 2015 12:24 PM
Jake99
Aug 8, 2015 07:56 AM
05GMC4.8
Aug 7, 2015 09:55 PM
Cowboy17
Jul 9, 2015 08:22 PM
