Cranked up the boost on my truck!!
Old Jul 7, 2008 | 10:13 PM
Stoichiometric's Avatar
Methanol.
Old Jul 11, 2008 | 02:42 AM
Spoolin's Avatar
GFYS and STFU
My 60E let go after I upped the boost from 6 to 8 psi. Methanol as Stoichy said is your next smart move.
Old Jul 11, 2008 | 07:44 AM
1BADAZZSS's Avatar
Lalalala can't hear you, what? lol.
So mainly the methanol will be used for cooling the iat's? And should my truck really be running that rich pegging my wideband? Thanks
Old Jul 11, 2008 | 12:19 PM
Spoolin's Avatar
GFYS and STFU
Methanol's main purpose is to boost the octane rating in order to prevent detonation, you mix it with water and that will help with lowering your IAT, or you can inject straight water and that alone would lower your IAT's.
Old Jul 11, 2008 | 05:24 PM
11.5:1 is a good number to shoot for.
Old Jul 11, 2008 | 05:52 PM
WJ MARK's Avatar
Oh yea huge jump goin to 10psi. I know the trans is prob feeling it too saying no,no, stop lol. Hopefully I can get the money saved up for the shift kit for the 80e and drop that puppy in. I only had 80% tq management taken just to try to pro long the stocker before I drop the 80e in. I still kind of bogs goin into 2nd gear but not like it did with the stock tune. Any clues as to what I sould do next running 10psi?
Thanks Thomas
My tranny should still be alive, somhow i messed up installing my shift kit oh well now i have a new one. I like strait meth over the mix. I noticed a power difference over mixing
Old Jul 11, 2008 | 08:36 PM
Mort's Avatar
Straight meth will cool some as well. Seems to make quite a big difference in my IATs with it on or off. If it comes in with low boost and I hold it a while it actually drops the IATs. Under WOT it seems to hold for a while and I see about a 30* increase over a 1/4 mile run. With it off I think I might see a 60* increase in IATs on the lower boost setting, Might not cool as much as water but it does cool as well as increasing the octane rating of the fuel mix.
Old Jul 12, 2008 | 02:45 AM
TURBO8's Avatar
Glad to see you have turned up the boost. Shoot for 11.5 afr, you are most likly under 10.0's if your guage's lowest reading is 10.0. I used full Meth as well, I loved that stuff.. Good luck bro.
Old Jul 18, 2008 | 11:07 PM
ls1CANTU's Avatar
9 Second Club
i'm useing a manual boost controller that i bought at advance and it works good. i have it set a 14 psi and it doesn't drop at all.
Old Jul 19, 2008 | 09:08 PM
1BADAZZSS's Avatar
My boost controller is fixed. Used a spring out of a ink pen that is not as stiff. Adjusted it and holds right at 10psi without spiking
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
GreyChevy
Jul 7, 2015 08:57 PM
