crank pinning HELP
Old Jun 14, 2013 | 02:10 AM
gonzo 6.2's Avatar
Default crank pinning HELP
what is the best thing to use for crank pinning??? a .250x.500 piece of drill bit or grade 8 bolt shank or steel round stock?
what in the hell kind of metal works best ?
Old Jun 14, 2013 | 02:06 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Steel round stock.
Old Jun 15, 2013 | 12:32 AM
D1SCSS's Avatar
I used a hardened steel roll pin?
Old Jun 15, 2013 | 01:49 PM
fastlsx463's Avatar
buy the ati kit from summit, its easy
Old Jun 16, 2013 | 01:05 AM
gonzo 6.2's Avatar
Originally Posted by AKlowriderZ71
Steel round stock.
doing it. .250x.500 oil hardend steel drill stock $4.00 for 3ft
AK will 1 pin do it? or 2
Old Jun 16, 2013 | 09:38 AM
TIM Z's Avatar
11 sec. Truck Mod
One pin will be fine .
If you ever have to pull the balancer good luck getting the hole aligned again , so only using one gives you more area to re drill if you need to in the future .
I only have one pin .
RustyD
May 23, 2016 07:04 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
Silver8ado
Sep 30, 2015 11:42 AM
trxmxzx
Sep 29, 2015 07:42 AM
