this could've been bad.
Old May 12, 2016 | 09:38 AM
madmann26's Avatar
Default this could've been bad.
I went outside (WFH today) to check things out and something made me reach down inside the crank pulley. Well fellas, my crank bolt decided to take a vacation. No idea when/where.
Luckily, I have a pin kit here and spare crank bolt (had planned on doing it at some point).
I think this also could be the cause of me throwing belts.
Old May 12, 2016 | 09:56 AM
03sierraslt's Avatar
Good catch, and ya I bet that has something to do with it.
Old May 12, 2016 | 09:57 AM
Choda's Avatar
what in the hell would make you randomly check the crank bolt lol
Old May 12, 2016 | 09:59 AM
madmann26's Avatar
BEATS THE :poop: OUT OF ME!
Old May 12, 2016 | 10:27 AM
renright83's Avatar
Did you reuse the crank bolt when you pinned the crank?
Old May 12, 2016 | 11:04 AM
Atomic's Avatar
I have a gauge for that
Had that happen before, but my crank pulley fell off going down the road
I recommend the ARP crank bolt (or the IW one if you have to use that one), and some red loctite.
Old May 12, 2016 | 11:06 AM
renright83's Avatar
Loctite is always good
Old May 12, 2016 | 11:16 AM
TXsilverado's Avatar
I've never had a problem with stock bolts. put down your purses and torque that ************ down with everything you got.
Old May 12, 2016 | 11:23 AM
renright83's Avatar
Me either new bolt torque to.. what 260ftlbs and done
Old May 12, 2016 | 11:42 AM
madmann26's Avatar
Can't reuse a bolt you don't have.
The proper process is:
1. using old bolt - torque to 250ft-lbs
2. take old bolt out
3. using new bolt - torque to 37ft-lbs + 140 degrees
