Considering Fabbing up my own turbo setup
Old Aug 22, 2005 | 01:41 PM
  #21
vanillagorilla's Avatar
Originally Posted by 2002yroneformula
1. Turbo Flange
2. Wastegate Flange (?)
3. and 4. Not sure on these
5. Wastegate dumping back into the DP
TIA
1. Yes
2. Yes
3. Expansion joint
4. Flange that bolts to factory driver manifold
5. No freakin' clue?
BTW, NXRicky I see no pics.
Old Aug 22, 2005 | 02:10 PM
  #22
NXRICKY's Avatar
Former Vendor
I just relooked and all seems be ok. Maybe the server it was on was down.
Ricky
Old Aug 22, 2005 | 04:15 PM
  #23
parish8's Avatar
single digit dreamer
the stock 6.0 manifolds will support insane amounts of hp. i believe W2W had a set up with stock 6.0 exhaust mainifolds and a big *** turbo and got over 1500fwhp.
Old Aug 22, 2005 | 04:20 PM
  #24
Hey Parish, can you confirm whether what I labeled as #5 was correct or not? Also, after looking at some of the pics from when you first had the setup installed, I saw that part of the liner was melted in the fender well. I see you've trimmed out around where it was, and just wanted to know if I would need to plan to do the same, or could I just use a little extra heat wrap on the header and DP.
Old Aug 22, 2005 | 04:24 PM
  #25
NXRICKY's Avatar
Former Vendor
Thanks no need for me to worry about those then.. LOL Now I just need to start turning the wick up a bit... A little boost a little timing a little more boost.... Yea thats the ticket..
Ricky
Old Aug 22, 2005 | 04:28 PM
  #26
Originally Posted by NXRICKY
Build it your self if you have the time and money...
Ricky
The time and fabbing involved isn't really a big problem. My main thing was from a $$$$ standpoint. I know going FI isn't cheap, but if I can save a little here and there....than that's more money I can put towards other things. I really would like to know if I could build it cheaper than I could buying it. I mean if I could save $1k or more than it's feasible to me, but not if it's only gonna be a couple hundred bucks.
Old Aug 23, 2005 | 09:24 AM
  #27
NXRICKY's Avatar
Former Vendor
to save a grand maybe... but it just depends on you, figurering out what you want and is needed, and not having to buy something twice.. And freight is a bitch if you get into a hurry... TO many blue and reds while I was building mine...
Ricky
Old Aug 25, 2005 | 02:03 AM
  #28
Well, I finally called and talked to Sam a couple days ago. Don't know who I've dealt with the last couple times I've called trying to get info, but definately will say that he helped me out a lot with the questions I had. Looks like I'll be giving them a call when I get ready to go with the turbo.
5.3Okasai
Mar 9, 2022 01:07 PM
Blue03sss
Mar 7, 2019 05:06 PM
iregret
Jul 27, 2015 10:32 PM
oharajo
Jul 18, 2015 09:24 PM
