Cluster boost gauge mount
Old Sep 11, 2010 | 08:07 PM
fastnblu's Avatar
Originally Posted by swift700
Hey guys, check out my boost gauge mounting location. It was a bit of work, I had to separate the glass with a hot razor blade, hole drill from behind through three layers of plastic and circuit board, insert the gauge and secure it, solder the lighting wires to the circuit board and run the hose to a tee in the vacuum line. I then glued the glass back on, reassembled it all, and to my surprise, it worked perfectly. The picture speaks for itself. I am more than happy with it. Having the cluster apart allowed me to clean up all the dust that had accumulated in there over the years. Running around 8.5psi.
I wish I would have done a step-by-step with pics. Of course, if you have tranny temp in this location, then it won't work for you.
Ya, I'm sure others would've too.
Original or not, doesn't matter. Looks really good & clean.
Vacuum is great for honing your driving habits to for better mileage and also to keep track on vacuum hoses IE leaks without having to pop the hood.
Agreed.
Swift, Autometer does have a gauge that only goes up to 15 or 20. I think I have it at home. I may have in my photobucket. Autometerhas them in a different series gauge tho, but it prolly has the vac gauge.
Myself, I won't ever will over 15#, so I wanted those hash marks & numbers as large as I could.
Also, I forgot if it's electric or mech. BTW, got a pic of your hot razor?
I'd still like to see some night pics.
Old Sep 13, 2010 | 10:05 PM
swift700's Avatar
I just used a utility knife blade held with Vice-grips and heated with a torch.
Here is a night pic. The camera makes the boost guage look a bit brighter than it is. Definitely different lighting than the rest but the contrast is OK.
chopperloco
Jul 10, 2016 10:45 PM
thunder550
Oct 8, 2015 04:53 PM
Matt C.
Aug 1, 2015 01:25 PM
Ls3silverado
Jul 31, 2015 04:22 PM
