Chevy TBI with a turbo?
Old Jan 8, 2016 | 12:48 PM
Andy Milopoulos's Avatar
Registered User
Originally Posted by NXRICKY
Right now I have a fuel plate that adds the extra fuel needed.. It uses 2 80 lbs. injectors. Standalone computer, contains map sensor, and a few other thinkgs(built into the plate), like linking to a wide band etc, and a mini fuel rail....
Let me know if you want to see the pics.
You will need a bigger pump and a bypass reg,(fmu to raise fuel psi), TBI trucks and 15psi is not much to play with.
Ricky
Hi what is the brand of the fuel rail system for the turbo tbi. I have a 1993 I'm installing a turbo on and need help with raising fuel pressure.
Old Jan 5, 2018 | 05:30 PM
Zmcc2010's Avatar
Registered User
Default 2.8 v6 turbo build
[QUOTE=kbracing96;3213381]I did it on a 91 S-10 with a 2.8 TBI V-6. Same concept, just a smaller motor. I put 4.3 injectors in the 2.8 TB and used a rising rate fuel regulator to increase fuel pressure for boost. Worked good for 6 lbs of boost and pretty cheep. I had about 700 bucks in that whole turbo setup. Let me know if you have any more questions about the setup.[/QUOTE
do you have any more info or pictures of this build i have a 89 s10 blazer 2.8 5 speed 4x4 that i really wanna turbo
Old Jan 6, 2018 | 11:11 AM
kbracing96's Avatar
Man it was a long time ago, lol. I think I did a write up one of the S10 forums but all i could find was this thread on it.
Smoking Turbo, HELP! - S-10 Forum
Old Feb 7, 2021 | 02:14 PM
Huscroft Michael Caleb's Avatar
Registered User
Default S10 turbo
I am doing the same an have installed a gt3582 t3 turbo on the 2.8, I installed the 4.3 injectors with an external boost referenced fuel pressure regulator, haven’t been able to drive it yet cause snow on the roads, my only thing is I ran dual 2” exhaust into single 3” feeding the turbo, I’m wondering if I have gone to big of pipe and should try something smaller, it is running rich, I only ran it for a minute, but I guess that wouldn’t be bad once I start pumping the boost to it, wondering if I should buy some chip burning software or do you think it will run ok? I’m looking for around 6-8 psi of boost
Old Feb 10, 2021 | 10:29 AM
Registered User
did you re-tune your ecm? or did you just run the injectors with the fuel regulator?
Old Feb 12, 2021 | 06:43 PM
kbracing96's Avatar
I used a fish tank air valve to bleed air to FMU to raise or lower the fuel pressure when in boost. I ran the stock ecm tuning and let it use the closed loop stock O2 for normal driving and then raised the fuel pressure when in boost to make it run right. Get yourself a wideband gauge to tune it.
4.3 Fanatic
Feb 1, 2014 02:55 PM
TURBHOE
Jan 24, 2008 09:19 AM
TURBHOE
Aug 1, 2007 11:38 PM
02Vortech
May 19, 2006 04:30 PM
TruckSS
Mar 17, 2006 10:04 PM
