fuel calculations
Old Jan 23, 2008 | 07:22 PM
TURBHOE's Avatar
Default fuel calculations
ok, if a fuel injector flows say 48lbhr at 58psi and you are runing 7psi boost should you subtract the amount of boost from the fuel system flow psi? it seems if the fuel system has to push against pressure then it would lower the amount it can push out. am i wrong on this? its hard to explain what i'm thinking but thats best i can do.
Old Jan 23, 2008 | 07:25 PM
truckmann's Avatar
I would think not. While I see your thinking I think the pressure difference would have to be much greater to have any effect.
I would also wonder if the opposite might be a little true where the venturi affect would actually help pull some fuel out of the injectors.
Old Jan 23, 2008 | 08:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by 4.8T
ok, if a fuel injector flows say 48lbhr at 58psi and you are runing 7psi boost should you subtract the amount of boost from the fuel system flow psi? .
Yes.
Old Jan 23, 2008 | 10:32 PM
truckmann's Avatar
I stand corrected!
Pressure calculation: the fuel pressure required increases with the square of the boost pressure ratio:
Example: 6 psi boost is a pressure ratio of 1.41. With stock fuel pressure of 36 at zero boost, than:
Needed fuel pressure = ( PR2 x 36) + boost = (1.412 x 36) + 6 = 77.5 psi
http://www.racetep.com/begiregins.html
Old Jan 23, 2008 | 10:57 PM
MikeGyver's Avatar
Your abacus must need oiling. My calculator sums that equation at 56.832.
Old Jan 23, 2008 | 11:01 PM
truckmann's Avatar
You know I thought that number looked way high, but I didn't check it out. I just copied it from the page it came from. Looks like they made a mistake.
Old Jan 23, 2008 | 11:02 PM
MikeGyver's Avatar
Oh, sorry. it's Top-End Performance's abacus. Anyway, aren't most boost referenced pressure regulators set up to raise fuel pressure at a 1:1 ratio?
Old Jan 23, 2008 | 11:04 PM
Stoichiometric's Avatar
Yes, the differential between the rail pressure and manifold pressure are what determines the flow rate.
Old Jan 24, 2008 | 12:13 AM
kbracing96's Avatar
The same is true with vacuum, that's why returnless fuel systems have a sloped flow rate table in the PCM and return system have a flat flow rate table.
Old Jan 24, 2008 | 06:56 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Yes. If you are running a 1:1 boost ref'd reg, then this problem goes away.
