Change of plans... Swapping bump stick
Old Jul 31, 2012 | 07:23 AM
  #121
RibeiroBJJ's Avatar
Praise The Lowered
X2 on the springs..Also the ls6 cam has a smaller base circle than a standard ls1/4.8 cam..thats what the extra .025 length (over 7.4) on the pr's was for..So they are pushing on the lifters a bit more
Old Jul 31, 2012 | 08:46 AM
  #122
foose04's Avatar
Better to have extra preload as to not enough? Just not lookin to damage the stock lifters.
Old Jul 31, 2012 | 09:22 AM
  #123
BigKID's Avatar
Higher seat pressure coupled with the more aggressive ramp of the cam is going to make the valve train a little louder as you are going to hear the valve smack the seat regardless of preload. A consistent sewing machine sound is good, lots of clicking, clacking and tapping is not. Not enough preload, you are going to have a sloppy valve train (i.e. noisy) at low rpm. Too much preload, the valves may not completely close at high rpm due to the lifter pumping up.
Without knowing the base circles the LS6 and TU1, I cannot say if you have more/less preload with the same pushrods but I would wager that the TU1 has a smaller base circle thus reducing your lifter preload with the same length pushrod.
Old Jul 31, 2012 | 04:59 PM
  #124
Im running 7.4 PR with my TU1, LS7 lifters and Dual springs. It does have some sewing machine noise but thats normal with aftermarket valvetrain components.
Old Aug 1, 2012 | 11:17 AM
  #125
foose04's Avatar
Awesome info guys, thanks. The Ls7 lifters are a different length then stock correct?
Trans is on the dyno today so that's good news, maybe next week she'll be on the streets again!
Old Aug 1, 2012 | 12:08 PM
  #126
sprayedenali's Avatar
Straight cut gears are fun! They make cool noises... Hahaha
Old Aug 2, 2012 | 02:29 PM
  #127
02'Z71ONDUBZ''s Avatar
Yes the LS7 lifters are different length. I believe they are taller and need 7.35 pushrods on a stock setup but don't quote me. I would buy a pushrod length checker to check your preload regardless. I did quite a bit of reading on preload because I just put a set in myself, best consensus I could come up with was between .060- .09x. Theres a ton of conflicting information out there on these. You should pick up a set of 799's or 243's if your pulling the heads.
Old Aug 2, 2012 | 05:16 PM
  #128
slowec's Avatar
Only my first gear is cool sounding
Old Aug 4, 2012 | 04:51 AM
  #129
dirty_old_chevy's Avatar
Results... or vids.... Please....
Old Aug 4, 2012 | 06:21 AM
  #130
DTHPROOF's Avatar
Definitley in for results. I always look forward to the Foose threads.
