Change of plans... Swapping bump stick
#121
X2 on the springs..Also the ls6 cam has a smaller base circle than a standard ls1/4.8 cam..thats what the extra .025 length (over 7.4) on the pr's was for..So they are pushing on the lifters a bit more
#123
Higher seat pressure coupled with the more aggressive ramp of the cam is going to make the valve train a little louder as you are going to hear the valve smack the seat regardless of preload. A consistent sewing machine sound is good, lots of clicking, clacking and tapping is not. Not enough preload, you are going to have a sloppy valve train (i.e. noisy) at low rpm. Too much preload, the valves may not completely close at high rpm due to the lifter pumping up.
Without knowing the base circles the LS6 and TU1, I cannot say if you have more/less preload with the same pushrods but I would wager that the TU1 has a smaller base circle thus reducing your lifter preload with the same length pushrod.
#127
Yes the LS7 lifters are different length. I believe they are taller and need 7.35 pushrods on a stock setup but don't quote me. I would buy a pushrod length checker to check your preload regardless. I did quite a bit of reading on preload because I just put a set in myself, best consensus I could come up with was between .060- .09x. Theres a ton of conflicting information out there on these. You should pick up a set of 799's or 243's if your pulling the heads.
