Can you build boost off the line with a 2-step?
Old Jul 23, 2016 | 07:44 PM
GMCtrk's Avatar
Brake boosting is a complicated thing.
If you aren't going positive pressure and going thru the brakes, it's still possible you could do better with hydroboost, but you aren't losing brake power from lack of vacuum.
Converter could be too tight. But beware, if converter becomes too loose, you'll be losing tons of power thru heat down the track.
Transbrake is ideal.
Whats your trap speed
Old Jul 23, 2016 | 07:45 PM
smokeshow's Avatar
Mod with training wheels
Originally Posted by TAPyvehc93
See here is the thing. If I am not building any boost by just foot braking it and its already pushing through the brakes then adding a hydro boost would not really do anything for me then right.? I would think the converter is whats causing it to push through the brake and not lack a vacuum since there is not boost yet. Just my idea though.
Depends...that was a 4wd. Torque distributed to all corners with all of them fed by hydroboost which will continue clamping hard as vacuum goes away. If youre 2wd, may not work so well...but hydroboost does still help.
Old Jul 23, 2016 | 08:38 PM
TAPyvehc93's Avatar
114. 3-4 shift needs some work though and it may be pulling timing up top.
Old Jul 23, 2016 | 10:30 PM
GMCtrk's Avatar
Good enough to easily rip most of the junk at RPR on a friday night
Old Jul 24, 2016 | 08:06 AM
TAPyvehc93's Avatar
HAHA yes. I think ill be doing the rear shock relocation first with some better shocks , then I'll try a two-step and if the brakes push through then ill get the hydro boost.
4xRCSS
Mar 4, 2016 09:40 AM
ZBass28
Apr 22, 2002 10:49 AM
F8L Z71
14
Feb 13, 2002 12:35 AM
GREGGO
Jan 6, 2002 03:39 PM
