Can you build boost off the line with a 2-step?
Old Jul 23, 2016 | 06:20 PM
TAPyvehc93's Avatar
Default Can you build boost off the line with a 2-step?
Ran my truck at the track last night with the new setup and it did a best of 11.999 in this very hot and humid Texas weather. I was pretty excited about that but its still cutting 2.0 60fts lol(5200lb truck). This was with brake stalling to about 2200-2300 before it would want to push through the beams. Also on 28" MTs. If I installed a 2 step and a hydro boost, do you think I would be able to build boost off the line? I feel like if I could get these 60's down it would run 11.7-11.8's?
Old Jul 23, 2016 | 06:31 PM
GMCtrk's Avatar
Id be very pleased with that time given a dogshit slow 60'
Get hydroboost, build 5-10 lbs on the tree and pull 1.6s. You'll chop off at least half a second on your quarter.
Old Jul 23, 2016 | 06:35 PM
smokeshow's Avatar
Mod with training wheels
Yes it builds boost.
https://youtu.be/PKZ-lB-TBX8
Old Jul 23, 2016 | 06:36 PM
TAPyvehc93's Avatar
2800 yank,Stock 6l80e no trans brake or anything, 3.42 gears.
Old Jul 23, 2016 | 06:40 PM
TAPyvehc93's Avatar
Specs? What trans, what converter, hydro boost?
Old Jul 23, 2016 | 06:42 PM
smokeshow's Avatar
80e, yank SC3000, hydroboost. Build as much boost as you want
Old Jul 23, 2016 | 06:57 PM
TAPyvehc93's Avatar
Could you foot brake it to 3000 without the 2-step and did it build any boost at all without it?
Old Jul 23, 2016 | 06:59 PM
TAPyvehc93's Avatar
Sounds like a hydro boost and a 2-step is my next mod to get this heavy truck off the line.
Old Jul 23, 2016 | 07:11 PM
smokeshow's Avatar
I have been as high as 14psi on just hydroboost alone. That's just when I let off the brake....it would keep going.
Old Jul 23, 2016 | 07:26 PM
TAPyvehc93's Avatar
See here is the thing. If I am not building any boost by just foot braking it and its already pushing through the brakes then adding a hydro boost would not really do anything for me then right.? I would think the converter is whats causing it to push through the brake and not lack a vacuum since there is not boost yet. Just my idea though.
