Can I Go F/I on a 6.0L for $4,000 or less
Old Dec 3, 2006 | 10:20 AM
nightrunner's Avatar
Mr. Obvious
since you have an 80e just get a shift kit and youd be good to go
Old Dec 3, 2006 | 10:28 AM
TG02Z71's Avatar
Originally Posted by FastCrewCab4x4
So would my 4l80e tranny not be happy with a blower? I thought they where pretty tough. I could picture the stock Ring gear snapping like a cheap hoseclamp. especially with the wider tires I have.
It will last compared to any other truck trans as long as you have the shift kit and its tuned right but I just wanted to make light of the other things that can go south under the stress of added power+your towing needs.
Whenever I hear someone ask about going FI there are many things that get left out of the conversation, that is until they blow up.
If I had to do it all overagain I would have went with a 4l80 swap and possibly a 6.0l to start with instead of the 5.3l. Hindsight is a great thing, too bad it doesn't help.
Sounds like your truck is a great place to start, you have all the things I wish mine was except the added weight.
Happy boosting!
Old Dec 3, 2006 | 10:42 AM
adam1803's Avatar
You will definetly need to go with a used setup to meet your budget, but there is nothing wrong with that. And it sounds to me that you would probably be most happy with a radix, the low end torque it makes will make towing easier and also get the weight of a big truck up and going better then a turbo or centrifugal supercharger.
Old Dec 3, 2006 | 10:51 AM
thunder550's Avatar
High on diesel fumes
https://www.performancetrucks.net/fo...d.php?t=379457
Shameless plug
calsdad
Jun 14, 2023 11:07 PM
zblee
Nov 11, 2015 12:41 AM
old motorhead
Sep 29, 2015 08:22 PM
Forcefed81
Sep 8, 2015 10:02 PM
