Which cam/springs in 4.8 before turbo install? Want a little loppy sound
I know the ls6 cam and springs is a great addition to the 4.8.
I am going w/ kb racing mpt70 or the 76 havent decided yet.
Looking for a decent loppy idle but nothing out of control. Boost will be around 10psi, not sure if i'll make 15psi like foose04.
Do want to make 500 whp daily driver tho too!
My cam specs in sig with yellow LS6 springs. Makes 435hp on 91 octane with 112 radix at 10lbs. Tons of low end tho, has 400 ft/lbs starting at 2000 rpm
Idle video-
http://www.youtube.com/watch?v=ZdNlijX8lHQ
Idle video-
If I were you I would have a custom cam spec'd for what you want. If you don't want to go that route, just go with the Z06 cam. You would probably make as much or more power with one of them anyway lol. I'm not sure off the top of my head of any cam I would want in a turbo 4.8 that would have some chop to it. The only off the shelf turbo cam that I know of that would have much chop to it at all is the Speed Inc. TU line of cams. Mainly the TU1, but I think it will be a little big for a 4.8.
Also, you will regret going with the 76 in a 4.8 on the street. JMHO
