build got out of hand now looking for advice
#22
had no intentions of building a 2nd truck, I still have my 87 383 stroker that's forged, splayed, studs & etc. I had that engine out and redone haven't even ran it still needs a tune that was suppose to be my "fast" truck
#23
Kind of hard to understand unless you look at a tune. The boosted regions where meth is used won't be used when you turn the boost down. So if you have meth coming on at 12 psi, all the 12 psi and higher boost pressures will be tuned for the increased fuel. Anything 11 psi and under, will be tuned for strait gasoline. So when you "turn it down" you'll just be running the lower boost pressures under 11 psi where meth isn't needed. Hope that makes sense
#24
dropped the block of to the machine shop, he's going to looking it over and see what it needs i was told by looking at it every thing looks ok and should be able to just hone it new rings & bearings but hes going to mic every thing just to be sure....should have an answer by tomorrow fingers crossed!
he said the piston can be recoated for $20 each is it worth the $160 to do it?
#26
#28
If your block is good at stock bore you could just buy my pistons and rods so I can get the over sized ones I need. Wiseco custom junk yard dogs and callies 6.100 rods. I had them made to stick .002 out of the hole with 6.100 rod.
ARC
57
Feb 21, 2022 10:54 AM
