build got out of hand now looking for advice
Old Mar 23, 2014 | 01:20 PM
MikeGyver's Avatar
Build got out of hand. No ****. That is what the "Forced Induction" section should be renamed.
Old Mar 23, 2014 | 01:30 PM
smokeshow's Avatar
Mod with training wheels
I still haven't seen anyone break the 05+ bottom end with a good tune. Mine has seen 26psi before. Not on purpose of course, but its been there lol. And stock48 has done 26-27psi on purpose...but he's a savage.
Old Mar 23, 2014 | 02:12 PM
gamble686's Avatar
Dbrods has bent quite a few Ls2 style rods. Not sure about his tuning style, but oh well.
Old Mar 23, 2014 | 05:27 PM
stroker87's Avatar
can i just swap my rods out for the new style or do pistons need to be replaced to?
Old Mar 23, 2014 | 08:47 PM
tim wellington's Avatar
Default o5 rods pistons
yes pistons and rods have to be changed lq4 pre 05 press fit rods 05 + floating pins
Old Mar 24, 2014 | 02:47 PM
AkSSS's Avatar
Originally Posted by gamble686
If you're wife will be driving the truck I would suggest running a boost controller with a low boost setting for the wife and have your meth kit boost referenced. That way it will be nice and safe for daily driving and you can easily set it on kill when you want it.
This is how I run my meth setup. I have a electric boost controller. Wastegate spring is at 8 psi for just normal driving. Then when I turn on the boost controller, it also activates the meth setup. My boost controller is adjustable up to an extra 15psi. It works very well. And it is just a matter of a switch if something pulls up beside you. lol!
Old Mar 24, 2014 | 11:34 PM
stroker87's Avatar
this is what I dont under stand? if the truck gets tuned for meth and xx# how does it run correct when you have it turned down and the meth off?
Old Mar 24, 2014 | 11:40 PM
oakley6575's Avatar
Kind of hard to understand unless you look at a tune. The boosted regions where meth is used won't be used when you turn the boost down. So if you have meth coming on at 12 psi, all the 12 psi and higher boost pressures will be tuned for the increased fuel. Anything 11 psi and under, will be tuned for strait gasoline. So when you "turn it down" you'll just be running the lower boost pressures under 11 psi where meth isn't needed. Hope that makes sense
Old Mar 24, 2014 | 11:44 PM
Razor's Avatar
BMF
Glad you can still say this!
Old Mar 24, 2014 | 11:58 PM
stroker87's Avatar
yes it does make sense to me, I understand tune maps a "little" I messed with my stealth ram injections before
thanks!
