broken Magnacharger!!
Old Feb 26, 2007 | 02:23 AM
Z-71's Avatar
Exclamation broken Magnacharger!!
hi guys ,,,
My friend has 2005 manual 5speed 4.8L gmc Z-71 truck, he installed a magnacharger with 3.70 pulley 3 months ago and ran on it around 3000-3500miles ,, two days ago he was racing a guy with bmw 645 ,, they started from second gear when he pushed his truck to the third gear the magnacharger shutdown!! the roots's sound disappeared, the power went down, and the truck ran as the stock truck even worse. The supercharger's pulley works its turn around but we can't hear any sound from the supercharger even at high RPM!!
Is this happened before?
Old Feb 26, 2007 | 03:41 AM
Blown02Sierra's Avatar
Have you checked the blower or intake manifold for damage? Possibly the diverter valve stuck open? Hopefully BlownChevy will chime in.
Old Feb 26, 2007 | 04:01 AM
Z-71's Avatar
Blown02Sierra ,, nothing looks bad from outside, no leaks engine's sounds normal like
a stock engine!!, even at high rpm the supercharger has no sound at all
anyway thank you very much for your support
Old Feb 26, 2007 | 05:55 AM
Bowtie70SS's Avatar
If you take the belt off you should be able to rotate it by hand back and forth. You should feel the resistance from the rotors and they may make a slight clunk if turned. The bypass valve does sound like a possibility though.
Dave
Old Feb 26, 2007 | 09:13 AM
James B.'s Avatar
Sounds like a broken input shaft on the supercharger. Even if the bypass was open you'd still hear the whine.
Old Feb 26, 2007 | 10:30 AM
BlownChevy's Avatar
blownerator
25 Year Member
sounds like the blower drive shaft might have taken a **** on ya. Give Magnuson a call 805-642-8833, ask for David.
Old Feb 26, 2007 | 12:16 PM
Z-71's Avatar
Bowtie70SS,, i'll do it ,,, thank you very much
James B. ,,,, yea i thought that too, because the pulley turn around but nothing else. Thank you very much
BlownChevy ,, Thank you very much for your support ,, i will call him as soon as possible.
madmann26
Apr 29, 2020 09:17 AM
Avalanche2002
Nov 30, 2015 07:31 AM
gmcyukon
Oct 3, 2015 11:03 PM
Velocity1
Oct 2, 2015 08:01 AM
trevorh1
Sep 27, 2015 08:47 PM
