broken Magnacharger!!
hi guys ,,,
My friend has 2005 manual 5speed 4.8L gmc Z-71 truck, he installed a magnacharger with 3.70 pulley 3 months ago and ran on it around 3000-3500miles ,, two days ago he was racing a guy with bmw 645 ,, they started from second gear when he pushed his truck to the third gear the magnacharger shutdown!! the roots's sound disappeared, the power went down, and the truck ran as the stock truck even worse. The supercharger's pulley works its turn around but we can't hear any sound from the supercharger even at high RPM!!
Is this happened before?
If you take the belt off you should be able to rotate it by hand back and forth. You should feel the resistance from the rotors and they may make a slight clunk if turned. The bypass valve does sound like a possibility though.
Dave
Dave
Bowtie70SS,, i'll do it ,,, thank you very much
James B. ,,,, yea i thought that too, because the pulley turn around but nothing else. Thank you very much
BlownChevy ,, Thank you very much for your support ,, i will call him as soon as possible.
gmcyukon
Oct 3, 2015 11:03 PM
