Fuel pressure dilemma.
Old Feb 25, 2007 | 08:29 PM
Ruffrider5.3's Avatar
Default Fuel pressure dilemma.
Ok, I have just spent the last two hours reading the search column for fuel problems. My eyes are bleeding so I will just ask. I have an intank 255 pump. Under boost, say 5 psi the pressure is at 62 or so ,but as soon as I hit wot the pressure drops off and my wideband confirms by going lean to about 13 or so before I lift. When I was putting my fuel pressure gauge on I went to bleed the system down, but there was no pressure to bleed off. The truck starts easily with no problems. The truck was sitting a day or so before I put the gauge on. Is that normal for it to bleed down by itself? The fuel pressure stays good until I get to wot then blaaaaaaaaaa, it starts to take a dump. Any ideas? It is an 03. Could it be a voltage problem? I think the pump could be going out, just want more ideas.
Old Feb 25, 2007 | 10:25 PM
parish8's Avatar
single digit dreamer
you could try a new filter.
where did you get the pump? are you sure is it better than the stock pump you pulled out?
Old Feb 25, 2007 | 10:39 PM
Derek @ EDO's Avatar
FormerVendor
do you have over 1/4 of a tank, some people experience this with the fuel pump swap running less then 1/4 tank.
Old Feb 26, 2007 | 12:59 AM
bostinchevy13's Avatar
When Fuel Pumps Star To Fail The Will Start To Fail At High Pressure So Check It Out
Old Feb 26, 2007 | 11:46 AM
Should I put the stocker back in for now or just get another 255? Not a daily driver so no worries there.
Old Feb 26, 2007 | 12:11 PM
zippy's Avatar
The stock pump should have been fine at that point.
Old Feb 26, 2007 | 12:16 PM
put the stocker back on just stay away from wot or anything of that nature cause that pump cant supply those thirsty #44
Old Feb 26, 2007 | 02:13 PM
Then I wont bother putting the stocker back in, I dont want to have to change it again so I will just buy another 255. The fuel pump would also be the reason it was not holding pressure at the rail, correct?
Old Feb 26, 2007 | 03:04 PM
zippy's Avatar
I've know some that have ran the stock pump on Radix'd 6.0L's and didn't run out of pump.
Mossyoakglock
Aug 28, 2015 12:49 PM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
